Old 05-24-2005, 10:21 AM
bjl_sailor bjl_sailor is offline
Rep: 10 Posts: 66
Fasteners as well as epoxy at sheer/deck joint?
I'm decking over my 19' sportboat with a 1/4" plywood layer and then another laminated layer of 1/4" meranti strips. With first ply subdeck down via drywall screws and fender washers as clamps -- I'm wondering if I should also put stainless screws into the sheer/deck clamp -- it's 1/2" cedar sheathed on the outside laminated to a 1/2" x 2.5" meranti strip on the inside -- so a 1 1/4" #6 or 8 will go. The scantlings also call for an 8" tape to cover the seam -- are the screws overkill/unecessary wieght?
Old 05-26-2005, 08:26 PM
Rep: 2891 Posts: 8,798
This sounds to be a pretty heavy deck, for a sport boat. If the screws are hitting the cedar, they will not have much holding power. This sounds like a cedar strip hull, with a meranti sheer clamp. You'll want to hit the clamp with the screws and they will provide a lot of sheering load strength, plus the pull out needs of the deck. Fillets and tape are your real structure, the weight of a few fasteners shouldn't effect anything.
Old 05-26-2005, 08:39 PM
cyclops cyclops is offline
Rep: 29 Posts: 1,059
I have acquired the wood screwing habit of drilling the screw pilot hole, running the screw all the way in, back it out, put 2 or 3 drops of THIN instant glue down the hole. Wait 1 hour, final run in of screw. Should the screw be too tight? Out, bar soap on the first 1/2 of threads. Pratice on scrap first. Never know you have weak wood or bad grain direction.
Old 05-26-2005, 08:47 PM
1/8" and glue or epoxy of the strips is overkill, if the deck has any upward bowing in it with curved deck supports under it. 3/8" total ply is the siding thickness for wood runabouts up to 50 mph.
Deck To Hull Joint VIKING Boatbuilding 16 10-06-2008 08:57 PM
Epoxy crystallization jfblouin Materials 4 09-15-2005 12:19 PM
Easier way for balsa core deck replacement? pago cruiser Boatbuilding 4 06-01-2005 07:20 PM
Epoxy......how much i need? {NW}BKUSA Wooden Boat Building and Restoration 7 01-21-2005 06:14 AM
Crack in joint of two piece hull... ErikG Sailboats 5 04-08-2004 12:23 AM
