Old 09-12-2006, 09:42 AM
Mr V Mr V is offline
Rep: 10 Posts: 20
Epoxy Layers, Sanding, and Paint
I am putting a good coat on the keel and bottom of my little 8 foot skiff. I have just put the first coat of epoxy on one side of the keel, as it is on it's side to prevent the epoxy from running off the sides of the keel.
I have read through several topics on this and still have a question. In one place it states that you sand after the third coat, in another it says to sand after each coat.
My questions are:
1. Which method should I follow as I desire the best 'smooth' I can get, for a first timer at epoxy?
2. I am actually doing a repair job on this boat. It started out with no epoxy finish, just ply and enamel latex paint. After an unfriendly move (^$#%#$ movers), my hull ended up with a crack, so I figured I would just epoxy the bottom of the hull and put a full size keel on it at the same time (Don't laugh, it actually looks good). I only sanded the paint off of the bottom of the hull and want to keep using this paint. Is my Enamel Latex paint going to stick to the epoxy after I get it all sanded down smooth?
Thanks!
Old 09-12-2006, 10:05 AM
hansp77 hansp77 is offline
Rep: 200 Posts: 691
as far as I know,
First you should wipe down thoroughly the cured epoxy with metho to remove any blush (even if it is a non-blush epoxy).
Then sand between every coat.
Alternatively, and the method I have used is to wait for the first coat to go tacky, and then apply another coat- wet on wet. I think, this way the amine blush just follows on into the next reaction.
I think you can do three coats like this- however, an expert will surely correct my errors...
For painting, again, wipe with metho, sand, and then prime with a proper primer suited to epoxy, and to whatever your topcoat paint is.
Hans.
Old 09-12-2006, 10:26 AM
Toot Toot is offline
Rep: 17 Posts: 274
Definitely sand any coat that has fully cured for a few days or more.
You can just go on top of anything that hasn't cured for more than 24 hours or so.
Are we off-topic yet?
Old 09-12-2006, 10:34 AM
Rep: 10 Posts: 20
Originally Posted by hansp77
as far as I know,
Just to make sure I am clear, what are you calling metho?
Old 09-12-2006, 12:23 PM
Rep: 200 Posts: 691
metholated spirits,
or thinners, or a solvent of some type.
Old 09-12-2006, 01:02 PM
Rep: 10 Posts: 20
metholated spirits,
Got it! Thanks.
Old 09-14-2006, 12:25 AM
BOATMIK's Avatar
BOATMIK BOATMIK is offline
Deeply flawed human being
Rep: 190 Posts: 273
HI,
There is a whole lot of different info here on my FAQ
http://www.storerboatplans.com/Faq/faqindex.html
suitable for getting an overview on how to use epoxy and get reasonable surface finishes as well as use the material efficiently.
Best Regards
my boat pages
Old 09-18-2006, 02:07 PM
JR-Shine JR-Shine is offline
SHINE
Rep: 50 Posts: 282
The best way to get a smooth finish is to apply many thin coats vs. a couple heavy coats. Using a foam roller cover, you roll an EVEN and thin coats. This will build up equal thickness all over the part. If you use a brush, some spots will have too much (sand it down) and other parts will not have enough (apply more) this adds up to a lot of wasted epoxy.
Ideally, you roll on subsequent coats as soon as the previous is tack free, that way you dont have to sand in between - only the last one.
Joel
www.boatbuildercentral.com
apply'n epoxy paint to hull.. harveydoryguy Fiberglass and Composite Boat Building 0 04-28-2006 12:26 AM
Epoxy Layup: Paint in the Mold Doug Lord Fiberglass and Composite Boat Building 11 12-27-2005 05:35 PM
Paint System For Epoxy Hull VIKING Boatbuilding 5 02-02-2005 03:02 AM
Epoxy, Paint, or what??? Mr V Wooden Boat Building and Restoration 13 01-08-2005 06:45 PM
Paint question over epoxy zember311 Boatbuilding 5 11-26-2004 02:22 PM
