| I slice teak veneer and other species + manufacture epoxy cold molded products for a few years. When it comes to making a hull, I would never imagine saving on glass cloth but I would rather save on buying a cheaper epoxy (eg: good quality unknown brand one but not west system), and cheaper wood specie...again, this is if I had no other option as dropping down the costs...
__________________ "Simplicity is complexity resolved'' TEAKCELL |
| that's sounds like a better idea . i will look into that aption . thanks life begins where land ends |
| Glass is said to increase the cantilever strength of ply by 2x or 3x, and the designer will have taken that into account when specifying the ply thickness. It may be OK to leave off the glass if you use thicker ply, but as Paul says it's probably false economy except in very small boats. However, I don't think it should be used for sealing, the boat should be watertight to start with. I admit I didn't use it myself, but only because my boat is light enough that I can carefully carry it and put it into the water, and it is not fast so it doesn't hit rocks hard. Remember that epoxy deteriorates in sunlight and must be protected by UV resistant paint or varnish.
| Glass Mould Over Wood | nancur373 | Fiberglass and Composite Boat Building | 2 | 08-07-2007 12:05 AM |
| Glass Mould Over Wood | nancur373 | Open Discussion: All Things Boats & Boating | 8 | 07-24-2007 12:30 AM |
| Glass Mould Over Wood | nancur373 | Software | 1 | 07-22-2007 11:49 PM |
| Plastic or glass over wood??? | ARGOS | Boat Design | 6 | 12-04-2006 07:13 PM |
| glass/epoxy over wood | jomo | Boat Design | 4 | 11-22-2005 10:54 AM |
