| Is Epoxy compatible with Glycol? Hi, I am planning to build a wharram Tiki 21 here in the Philippines. I've read that monoethylene glycol is a good preservative against rot. Would epoxy still adhere well to monoethylene glycol treated plywood? I need to apply fiberglass cloth/epoxy to the outside of the hull and coat the inside with epoxy. I am thinking about the glycol as an added precaution and added protection together with the epoxy/glass coating. Thanks! Tatoski |
| There's link in some thread (considering the very same subject) around here about the subject I'll check if I find it. But the answer is Yes with precaution.. |
| Thank you very much TeddyDiver for leading me to the right connections! I've clicked on the threads and got a wealth of information. |
| Ethylene Glycol as a wood preservative | Trevlyns | Fiberglass and Composite Boat Building | 25 | 07-08-2011 11:45 PM |
| West System epoxy over D.E.R 331 epoxy | bobbychuong | Materials | 8 | 10-18-2008 03:13 AM |
| Does Epoxy = Epoxy | Poida | Wooden Boat Building and Restoration | 11 | 04-03-2007 04:44 AM |
| When to Epoxy | JosephKeel | Wooden Boat Building and Restoration | 8 | 03-03-2007 11:30 PM |
| epoxy primer sprayed on green epoxy laminate? | bntii | Boatbuilding | 12 | 10-16-2006 06:41 AM |
