Old 06-09-2011, 03:23 AM
Mat-C Mat-C is offline
Rep: 109 Posts: 242
Elements of Boat Strength
I am considering building a small strip plank boat as discussed briefly here
I will likely use Gerr's "Elements of Boat Strength" to calculate the scantlings.
The bulkheads will most likely be ply and as it is quite small, I was thinking of using the same for the ring frames - basically just a bulkhead with the middle cut out.
But the only reference I can find to using ply for the ring frames is towards the end of p.155, where Gerr says that "wherever the bulkhead can be located close to the calulated strip plank frame spacing - and where the bulkhead is essentially an unbroken ring (molded at least 6.75 times its thickness at the deepest cutout) - a separate frame is not required".
Am I correct in interpereting this to mean that, for instance if I have 10mm thick plywood "bulkheads" then I can cut out the centre, leaving 67.5mm as a ring frame?
Old 06-09-2011, 05:03 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1874 Posts: 3,357
That is how I interpreted the statement and I believe you are correct.
Hoyt
Boat Strength? ThePazza101 Boat Design 10 07-19-2010 03:43 PM
The Elements of Boat Strength: For Builders, Designers, and Owners wardd Boat Design 87 11-25-2009 10:46 PM
Questions about Dave Gerr's book The elements of boat strength Arvy Boat Design 7 11-01-2007 05:44 AM
Wooden boat floors strength Glider Wooden Boat Building and Restoration 3 11-11-2006 12:04 AM
Elements of Boat Strength Blue Heron Fiberglass and Composite Boat Building 24 01-12-2006 06:08 PM
