Old 01-31-2006, 05:09 PM
coh boat coh boat is offline
Drying Lumber
I need to dry some lumber for a boat building project and don't feel like waiting for it to air dry. Does anyone know of a company or person around the Ma. area with a Kiln that would dry lumber? Any help would be appreciated. Thanks
Old 01-31-2006, 09:47 PM
Rep: 505 Posts: 1,637
patience grasshopper;buy the time you find someone to dry your wood you could be halfway there .put wax on the ends of the logs and let them air dry.
Old 01-31-2006, 11:26 PM
nero nero is offline
Rep: 112 Posts: 624
If you have a lot of wood to dry, a solar kiln would be cost effective. It will also allow you to control the drying rate so as not to cook the wood.
When your finished with it, sell the kiln.
Some woods can be surfaced at high moisture contents and still remain flat. No need drying wood that will end up as shavings.
Drying wood axius0 Wooden Boat Building and Restoration 9 09-30-2005 03:33 AM
Anyone use fentress poly lumber / starboard.. etc? fireblade600 Materials 3 08-23-2005 10:13 AM
Lumber Supplier medphys3 Materials 2 07-11-2005 02:03 PM
vacuum bag hull drying Scratchy Dan Fiberglass and Composite Boat Building 3 05-30-2005 05:30 AM
plastic lumber fritzdfk Materials 2 03-20-2005 07:54 AM
