Old 01-14-2004, 06:40 PM
Willallison's Avatar
Rep: 2283 Posts: 3,468
Double planking details
I'm looking for a typical cross-section of a vee-bottom, double planked hull without rabbeted planks......
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 01-15-2004, 09:04 PM
Dave Fleming's Avatar
Dave Fleming Dave Fleming is offline
Old Geezer
Rep: 20 Posts: 49
IIRC, Pete Culler shows a few cross planked V bottom designs with details in his book Skiffs and Schooners and perhaps Chappelle does too.
Old 01-15-2004, 11:21 PM
Rep: 1397 Posts: 7,216
Are you looking for Ashcroft planking or double diagonal?
Old 01-16-2004, 11:42 AM
8knots 8knots is offline
A little on the slow side
Rep: 349 Posts: 266
I have a book called "V bottom boat building" By George Sucher I know it has some drawings in there I could scan and E-mail if you wish!
Dave is right I'll check my Chappelle too.
Let me know! 8
Old 01-18-2004, 05:16 PM
No, not double diagonal, just plain old double planking, but without rabbetts.
8 - that would be great
...I must get a copy of Chapelle....
Will
www.imaginocean.net
Old 01-18-2004, 11:50 PM
Rep: 349 Posts: 266
scans for ya!
Hi Will, here are 2 scans that I think might help you! Sorry it took me so long...I do most of my posting from work! I have a slow connection here at home. I did not know that article had been farmed out to other mags. But it has sparked an interest in those cats
Gotta run hope this helps a little! let me know if you need other stuff.
Will Brinkley (8)
Double planking details-w-all-1-jpg.jpg  Double planking details-w-all-2-jpg.jpg
Old 01-19-2004, 12:42 AM
Thanks Will - really appreciate the effort - alas they don't give the detail Im after
Perhaps I should elaborate... in one of my Westlawn lessons, I have to sketch construction details of various planking types. Most are given in the W/lawn text, but much of the detail in mine is illegible due to poor print reproduction.
So what I'm in need of is a typical section drawing showng the detail of the plank / frame / keel etc construction....
sorry I put you to all that trouble for nothing - should've explained myself better in the 1st place....
Will
www.imaginocean.net
Old 01-19-2004, 12:01 PM
Rep: 349 Posts: 266
No prob.... Let dig in tonight and see what I can dig up! I'm pretty sure I have some section drawings to scan! Be on the lookout later this evening.
8
Old 01-19-2004, 12:02 PM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,578
Will,
This is the best I could find.
Gary
Old 01-19-2004, 04:59 PM
That's more like what I was after, thanks Gary. My knowledge of wooden boat building terms is a little lacking to say the least. In the image you posted, does the planking feature a rabbett where it's joined to the garboard? If so, how would this be done without the rabbett?
Will
www.imaginocean.net
Old 01-19-2004, 07:05 PM
Senior Dreamer
Will,
Most of my library is for small boats, I could only find reference to double planking in a few places. In all cases the planking was rabbet into the garboard as is shown above. Hopefully Dave F or one of other old timers can help out here.
Gary
Old 01-19-2004, 07:12 PM
Thanks Gary - I imagine the outer planks are simply butted up against the garboard in the same way as the inner ones are.....
Will
www.imaginocean.net
Old 01-19-2004, 10:41 PM
Phin Sprague Phin Sprague is offline
Rep: 10 Posts: 5
Greetings, I have some experience with Alden Schooners circ. 1930. from various builders the practice was to have several strakes of full thickness garbord planks in the dead wood before starting the double planking. On one boat "High Tide" #456 built by MM Davis Gibson Island in 1931 there was white lead between the planks and no linen. There was no rabbet into the garboards. Inner planking was white cedar and back fastened into the outer mahogany layer.
Old 01-20-2004, 12:02 PM
Rep: 349 Posts: 266
Will, I dug through my stuff and Gary has the better of them. I have a nice section but it involves a centerboard trunk. I do have a drawing describing the elements of the keel rabbit or rebate Bearding, Mid, and rabbit line.
8
Old 01-20-2004, 02:47 PM
Senior Dreamer
This is from an old WB, it shows the keel as an attachment to the double planking. But it is for the Cutts method, where a Kevlar cord is set in between the planks.
Gary
Anyone familiar with Powerfoil sails? Mark Neill Sailboats 12 12-17-2008 11:07 PM
Strip planking vs wide planking jfblouin Wooden Boat Building and Restoration 26 08-11-2005 10:00 PM
plywood vs strip planking jfblouin Materials 2 03-08-2005 03:55 PM
dimensions of planking material genecoul Boat Design 3 04-03-2004 07:55 AM
double chine hull design azulkhai Boat Design 5 07-22-2003 07:28 AM
