| View Poll Results: WILL GLASSING THE BOTTOM OF AN OLD BOAT SAVE HER OR DESTROY HER | |||
| YES: IT IS THE BEST THING FOR HER | | 8 | 38.10% |
| NO NEVER: IT IS SERTAIN DEATH FOR HER | | 14 | 66.67% |
| Multiple Choice Poll. Voters: 21. You may not vote on this poll | |||
#31
__________________ Hoyt Lighting is very selective and will not strike crap. Wynand N http://www.genocidewatch.org/southafrica.html http://www.saabc.net/ |
#32
The NO doubt, NO question Part, you should have left. Though not completely out of the blue, if related to "cheap repairs". Done well, and done at the right time (not to cheat a customer), done with the right material, there is NOTHING wrong! I do not recommend sheathing, due to the many hundred mistakes one could make, and commonly are made. But IT IS A GOOD WAY TO ENCAPSULATE SOLID; HEALTHY WOOD! Just recently, I sailed a 1966 built, wooden boat in Winter conditions without any doubt about seaworthiness. But that was a professionally built and professionally sheathed (30 years later) vessel, not the average crap barge. the poll is not worth talking......... btw. |
#33
__________________ There's a difference between keeping an open mind, and letting the wind whistle between your ears... |
#34
| might sound kinda lame but my old grand father Robby wouldn't take on anything that wasn't wood. I learned a lot from that grumpy old guy and one might be a innate distaste for fiberglass. When I moved away from the Cape I could have taken a job in the local marina ( inland but still ) but basically it was 100% working with fiberglass. Not for me. I just dont really trust the stuff and I just dont feel like being covered in that stuff at the end of each day. Ill just stick with wood and be happy with it. I can say with a lot of confidence that wood likes to breath. If you baggy it up your begging for trouble. best of luck folks Im out B
__________________ I am skeptical of the deniers diatribe |
#35
| I agree about the wood.. From my experience over the years with fiberglass over older wooden boats is pretty much what has been covered here. The fiberglass work has to be of good quality, and yes at first when the wood dried the vessel becomes significantly lighter even though the extra weight of the fiberglass and resin was added. However, long term effects over the years is that the wood does not breathe properly and in areas where moisture collects from the fiberglass overlay wood rot occurs. It may be a short term solution as for the couple mentioned on the first page the circumnavigated the globe, but long term, I would stick with either a fiberglass or wood boat without the overlay.
__________________ Capt. John Banister, Marine Surveyor Palm Beach Gardens, Florida www.SuenosAzules.com |
#36
| There have been several posts commenting on the difficulty of drying a glassed-on-one-side boat. Is there an issue whether the boat in question is dry-moored or frequently hauled, vs launched and left? It seems to me that a boat in the water is hardly likely to get any more saturated as a result of having glass under her. Once hauled, that's another matter of course.
#37
#38
| I was always under the impression that glassing a wood boat hull is a not a good thing as the wood always flexes to some extent. This leading to cracks that hold water against the wood, rotten planks under a fiberglass shell, that is a bad combination even if the frames where still good. To take her out would require a calm day and a good supply of safety and rescue gear in an area that has at least moderate traffic and hope for the best. But from the previous posts you have about 5 to 10 years to do that, so where is she on the scale of "sure" to "OH S&*T". |
#39
If cracks in the fiberglass let water in and that's a bad thing, what about all the boats that have no fiberglass--and therefore stay wet all the time? Seems we have people on one side saying it can't be done without creating a disaster, vs people on the other side who do it routinely.....
#40
Daniel |
| Glass Bottom Buckets? | Timothy | Boat Design | 2 | 07-07-2009 12:16 AM |
| Wooden boat bottom coat | Ron56 | Materials | 3 | 11-15-2007 10:39 PM |
| Replacing wooden bulk head on glass boat | LEASEGUY | Fiberglass and Composite Boat Building | 21 | 03-22-2007 05:23 PM |
| Fiber Glass Sheathing of a wooden boat. | BCB | Wooden Boat Building and Restoration | 5 | 06-14-2006 12:46 AM |
| Glass Bottom Boats | Arrowmarine | Boat Design | 6 | 08-20-2004 03:27 AM |
