Old 04-22-2004, 06:02 PM
JOFRACON JOFRACON is offline
Rep: 10 Posts: 4
Definition - AMA
Good afternoon
As a newcomer to this sight I have an opening question.
I am building a catamaran . In all of the literature for the design an acronym for the hulls has come into play that I am having trouble locating a definition for. What does AMA stand for? What is the origin for this acronym? Where can I learn more about its origin?
Thanks
John C
Old 04-22-2004, 07:10 PM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,578
In multi-hull boats an ama (not an acronym) is an individual hull. I believe the term comes from South Pacific out-rigger canoes.
I will add it would be the float part of the out-rigger. How it would relate to a catamaran I’m not sure. On a tri the amas would be the side floats.
Gary
"The hand feeds the mind."
Weston Farmer
Old 04-22-2004, 09:54 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
Gary - say it ain't so.....
I always assumed it stood for "American Multihull Association"
Old 04-22-2004, 09:57 PM
Senior Dreamer
LOL!!!!
This boat stuff is perplexing.
Gary
Weston Farmer
Old 04-23-2004, 08:17 AM
Rep: 10 Posts: 4
Gary
Thanks Gary
I appreciate the rapid response. I am in fact constructing a modified Cat that has a shorter hull in the center. If that makes the outer areas an AMA so be it but, if AMA is not an acronym is it a word? What language? Tribe? Polynesian?
Still curious
John C
Old 04-23-2004, 09:28 AM
briany briany is offline
Rep: 10 Posts: 13
I believe the word ama originates from polynesia. There is another word proa which also refers to a catamaran, although in this case the sail is set on one hull which is intended to be the windward hull. I seem to recall that even the word catamaran is a corruption of a polynesian word. I need to re-read some books to confirm the above.
If you are interested a good place to start is a book called "Project Cheers" by Tom Follett, Dick Newick and Jim Morris published in Great Britain by Adlard Coles Ltd. This describes the building and sailing of a small boat which nearly beat the big boys in a single handed transatlantic race in 1968
Briany on St Georges Day
Old 04-23-2004, 09:52 AM
Senior Dreamer
John,
Welcome to the forum, as you see the answer sometimes takes a little sifting. I often type before I think, and the pro’s here, thankfully put me straight.
A Google search shows no "American Multihull Association", I did find this, maybe they are the offspring.
http://www.catsailor.com/namsa/namsa.html
The best multihull reference I have is Chris White’s, The Cruising Multihull. This is from that book. “All multihulls are made from hulls, not pontoons. ….. No one likes his or her multihull described as a pontoon boat.” And this. “A few designers and multihull sailors use borrowed Polynesian terminology to describe the parts of a trimaran. …. vaka for the main hull, aka for the cross beam, and ama for the float”
Gary
Weston Farmer
Old 04-23-2004, 09:54 AM
Robert Miller Robert Miller is offline
Rep: 12 Posts: 95
Ama is indeed a word.
It does indeed refer to the outboard hulls (floats).
And I do believe it is of Polynesian origin, as others have said.
But why are y'all slighting the equally interesting word for the cross-members that hold those hulls together?
These are Aka's.
Also Polynesian (or so I have always believed).
So your ama's are held together by your aka's.
Or, to put it another way, what's an aka without an ama?
Robert
Old 04-23-2004, 09:57 AM
Senior Dreamer
LoL!!!!
Weston Farmer
Old 04-23-2004, 04:42 PM
Rep: 10 Posts: 13
Gary and Robert beat me to it. Know we all know.
Old 04-24-2004, 10:45 AM
Rep: 1397 Posts: 7,215
I believe you are reffering to a "pod" if it is a small hull in between.
Old 04-25-2004, 11:33 AM
Chris Krumm Chris Krumm is offline
Registered
Rep: 10 Posts: 92
Robert -
I think an aka without an ama is a hiking board, ( or a proa or tri that's come to a bad end...)
Chris Krumm
Old 04-25-2004, 03:06 PM
SailDesign's Avatar
Gary - Next time you decide to take me seriously, PLEASE let me know. You owe me a keyboard for that one!
Steve
Old 04-25-2004, 03:31 PM
Senior Dreamer
Hey Steve, AMA is perfect, worth the search anyway. Inquiring minds always want to know.
Gary
Weston Farmer
fiberglass definition rturbett Fiberglass and Composite Boat Building 2 09-06-2005 12:52 PM
Definition of a "Trawler" Willallison Boat Design 6 11-09-2004 01:34 PM
Hard Chine Definition Needed Phosphor Boat Design 16 07-09-2004 11:11 AM
Definition of AMA JOFRACON Wooden Boat Building and Restoration 0 04-24-2004 05:56 PM
Mathematical definition of Boat planing astoffel0531 Boat Design 29 10-30-2003 04:08 PM
