Old 06-30-2008, 10:39 AM
lewisboats's Avatar
Obsessed Member
Rep: 1098 Posts: 1,731
Daggerboard/case clearance
What are we looking at for clearance min/max between daggerboard and case sides? I laminated up 4 layers of 6mm plus I am going to coat it a couple of times plus paint...so say 25.4 mm or 1 in total. What kind of clearance should I use between the DB and the case walls...1/16"...1/8"...friction fit?
Steve
Old 06-30-2008, 09:42 PM
Rep: 2891 Posts: 8,798
As close as you dare, considering it's wood. a 1/16" all around is a good tight fit, but if you have any swelling (not as much a problem with plywood) it'll jam.
Plywood isn't the best material to make blades from. Since half the grain is running in the wrong direction, it's not as strong as solid lumber, but is substantially heavier. If I had to use wood, I'd strip plank the blade, with (opposing annual rings) then a moderately heavy sheathing and a heavily reinforced leading edge.
Centerboards, rudders, daggerboards, etc. are best if made entirely from inert materials, which aren't subject to the ravages of the marine environment, don't change dimension with moisture content, etc.
snipe rpairing centerboard case pepin Boatbuilding 6 05-30-2008 07:44 AM
Can a cracked v-drive case be repaired? mongo75 Inboards 0 09-26-2007 11:59 AM
Stainless steel lift keel and aluminium case boony Boatbuilding 4 06-03-2006 08:27 AM
Yamaha wins dumping case Chuck Bates Propulsion 0 02-02-2005 02:23 PM
Help!!!! ( daggerboard construction or daggerboard design ) 01639770993 Boat Design 1 12-29-2003 01:56 PM
