| cutter stay hull attachment hello these are the possible inner forestay attachment arrangements. first one is easy to install. is it sufficient or should i do the other one Or do you have any other recommendations regards Ulas |
| Hi Ulas, Both have merit, the first model could be applied to bracket both sides of the bulkhead with the stay fitting bridging to fore & aft faces, incorperate some bracing gusset alighned to the wire load path or deeper to the aft bracket & also definately extend the strapping much! much! deeper down into the bulkhead with more bolts. Also put some extra hole or two into the external vertical component, they may come in handy for some thing like attachment of a deck bag for the staysail etc. So far as running the numbers on bolt loadings, material thickness etc I'll leave to the qualified engineers but consider the cross section of the attached wire & toggle pin & add a very big safety margin (400+%?) in like material sizes. Regards from Jeff. Last edited by waikikin : 09-24-2010 at 07:55 AM. Reason: extra words |
| #1 is simple and will work fine.
__________________ Gonzo |
| RIB hull design and tube attachment | jamesdedward | Wooden Boat Building and Restoration | 13 | 09-10-2011 02:22 AM |
| How long does your boat stay in the water? | CDK | Open Discussion: All Things Boats & Boating | 54 | 04-05-2011 03:01 AM |
| conversion from gaff cutter rig to bermudan cutter | el moro | Boat Design | 7 | 02-19-2010 10:13 AM |
| rotating mast stay attachment | bob the builder | Sailboats | 32 | 12-10-2009 09:27 PM |
| Mast stay | Ari | Sailboats | 13 | 04-05-2006 04:56 AM |
