  #46
Old 09-21-2010, 03:45 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
alan,
I did say wet and dry, 360 w&d is quite agressive mate, used wet of course.
I would agree if it was done dry.
  #47
Old 09-21-2010, 05:44 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
I see that now. My point was that a coarser grit will always work faster just so long as scratches don't telegraph through to a finish coat. Recently I built up the protection on my white oak coamings and 150 grit on a small random orbit worked very fast. My goal was to get down to a flat surface without any grain fissures remaining and then add a few (4-5) more coats. Until the grain was completely filled, I used only aggressive means to level the surface.
There is a difference, of course, between old and new varnish in terms of hardness. Softer varnish responds better to wet/dry.
  #48
Old 09-21-2010, 06:24 PM
Landlubber's Avatar
...yeah understand, you are right, you want to get rid of the hollows asap, and coarser grades do that of course, just remember to never remove wood, only varnish in the process.
carvel planking with thin planks Mohan Pakkurti Wooden Boat Building and Restoration 4 04-09-2007 10:35 PM
plywood epoxy vs. strip-planking LAZYJACK Wooden Boat Building and Restoration 14 03-31-2007 02:34 PM
Lapstrake or carvel planking for small home-made? rstevens Boat Design 3 01-31-2007 07:24 PM
Carvel planking: Stainless bolts or trunnels Scott Carter Materials 1 11-07-2006 08:15 AM
plywood vs strip planking jfblouin Materials 2 03-08-2005 02:55 PM
