Old 01-19-2011, 09:11 PM
Poida Poida is offline
Rep: 395 Posts: 1,072
Cost of materials
This enquiry is really aimed at my friends over on the East Coast of Australia.
Perth in the West, is not a place where you would find a lot of timber boats.
I would like to build a timber boat one day but the main obsticle I have is the cost of the sealers, glues and fillers that are available.
I would like to know if they are cheaper in the East and if it would be worth my while purchasing it from the East and shipping it over.
I purchased some this morning from BCF, International Epiglue 175gms $32.99
this works out to $188.50 per kilo.
Could you please advise me what price you are paying on the East coast.
Thanks
Poida
Old 01-19-2011, 11:13 PM
Rep: 3125 Posts: 9,403
It's likely BoteCoat is the product you want, in regard to sealing, sheathing and gluing the wooden elements of your project. I have a buddy in Adelaide that hasn't much trouble finding what he needs. Log onto www.woodworkforums.com/f29/ and see what's available from your fellow countrymen.
It would also be a wise decision for you to educate yourself about the products we use on wooden boats, as well as the techniques and methods to employ them properly. A good primer for this is the "user's guides" from westsystem.com and systemthree.com. Their free downloads will get you started in the coating, sealing, sheathing and gluing processes modern boat building uses.
Old 01-20-2011, 12:32 AM
gypsy28 gypsy28 is online now
Rep: 54 Posts: 95
Same product can be bought over here (Brisbane/Gold Coast) for $32.95, so a saving of 4c ,
I second PAR's suggestion of BoteCote, I have used it many time and am very happy
Old 01-20-2011, 07:00 PM
Thanks Guys.
The International brand of sealers, glues and fillers is all I have ever seen in the West, as I said, there are very few timber boats here, so for boat shops to stock too many brands would probably not be viable.
I've been to Queensland several times, only just returned, you would not see anywhere near as many timber boats here in Perth, so I assumed due to the larger turn over in timber boat materials that it would be cheaper in the East.
Par I'm an expert on timber boats, I've read all you posts. In fact I've printed them all out, copied them and my first book on timber boat building comes out soon.
I am currently rejuvinating a 6m boat and the amount of stuff I'm using on that brings me to the conclusion, when I build a new boat, the gunk to stick it together is going to be a major cost.
Thanks for the links Par
Old 01-20-2011, 11:36 PM
Send me a copy when you've got it in print.
Old 01-21-2011, 01:27 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,401
The wood fades to insignificance - it becomes les than 25% of the total hull cost after paint, epoxy, glass, fittings - and dont forget the consumables, so much acetone, glasspaper, etc etc
Old 01-21-2011, 01:45 AM
waikikin's Avatar
waikikin waikikin is offline
Rep: 596 Posts: 1,026
Poida, try FGI, apparently they have a distribution in Canning Vale? WA http://www.fgi.com.au/ or other Fiberglass material suppliers, -yellow pages, Regards from Jeff.
Old 01-21-2011, 03:01 PM
Wow, FGI is in Australia?
Old 01-21-2011, 04:12 PM
waikikin's Avatar
since the sixties, maybe longer, I wasn't around!
WOW do they have FGI in America too?
Old 01-21-2011, 04:28 PM
LP's Avatar
LP LP is offline
Rep: 385 Posts: 671
I don't understand the "m" and "mm" stuff.
LP
God bless the open minded people of the world. LP
Old 01-21-2011, 07:00 PM
Greg "m" means it tastes pretty good, but "mm" means it tastes really, really good . . .
Old 01-25-2011, 07:09 PM
Thanks for the info regarding fgi.
I have downloaded their product listing.
Now for the dumb question.
These appear to be polyester products, how do they differ from acrylic products. For example Par do they taste better?
Acrylic always seems to be recommended for timber boats are polyesters OK?
Old 01-27-2011, 04:26 AM
waikikin's Avatar
R180 epoxy
Poida, their R180 epoxy is what you want for timber, seems pretty good, I've used in the hundreds of kilos with no probs for sheathing & glueing of timber etc, here's a linky http://www.fgicomposites.com/nz/file...volume%202.pdf
All the best from Jeff.
Old 01-27-2011, 03:33 PM
rwatson's Avatar
Originally Posted by waikikin View Post
... their R180 epoxy is what you want for timber, seems pretty good, I've used in the hundreds of kilos with no probs for sheathing & glueing of timber etc, .... .
Thats good to hear, I just got a quote, and it is a lot less expensive than West Systems - just for a couple of kayaks and a plain vanilla houseboat.
$12 per litre instead of ~ $19 per litre
Old 01-28-2011, 03:54 AM
waikikin's Avatar
You'll still need to sprinkle some hundred$ & thousand$
How much does it cost... ?? ViennaYachtworx Boat Design 1 10-08-2009 05:43 PM
Cost mbhanoo Boat Design 3 06-07-2009 12:18 AM
Cost of materials for Fiberglass molds. jedclampit Fiberglass and Composite Boat Building 2 07-08-2006 06:01 PM
Cost of hull structure for different materials Alik Boat Design 2 08-29-2005 10:38 AM
Low cost composite materials danielro Materials 5 03-12-2004 01:16 AM
