Old 12-21-2004, 07:17 PM
Richard Petersen
LAKERUNNER, do you find that the plywood that has both sides of same wood has that bend wet - hold the bend when dry? I say that because I used 1/8" Birch and made a 8' WW II PT boat out of it. Was a piece of cake to wet bend and hold dry shape. Was I lucky?
Old 12-21-2004, 07:59 PM
lakerunner lakerunner is offline
Rep: 10 Posts: 48
you'll have great success with 1/8' birch. solid . or light laminate Birch has outstanding Bending properties .It is used to make some acoustic guitars. steamed for very short period of time and you can do just about anything with 1/8'' hard woods . It may have been luck making your choice . but fact as to the properties of your choice .
I was originally stating that 1/4'' luan is fine for small boat projects under low power.
And sub-flooring material is just not the answer to boat building. there are better product for the task at hand with comparable pricing.
post a picture . Of your PT Boat like to see it . good job
Old 12-21-2004, 08:36 PM
Richard Petersen
It was luck. I paid a cabinet maker to teach me in 2 minutes how to do the bow curves perfectly. Luck and skill work great together. I have pictures and a scanner to send them . How do I get them to you? Or this site?
Old 12-22-2004, 09:12 AM
Rep: 10 Posts: 48
Good ? . I have not found how to attach a file to this part of the site. You can go to the Gallery and post one. It will take you through it step by step.
Or you can just e-mail to me if you like .
djvcwg@yahoo.com
transom composition question pogden Fiberglass and Composite Boat Building 18 10-04-2004 09:55 AM
