Old 05-04-2007, 09:59 PM
nautical's Avatar
nautical nautical is offline
Rep: 10 Posts: 73
cold moulding vs fiber glass
hi everyone,
What are the advantages of coulding over fiber glass construction for say a 30 m vessel.
All your valued ideas, links and anykind of documents will be appriciated,
Thank you
Old 05-05-2007, 08:41 PM
Rep: 1133 Posts: 4,714
Both will be heavier then other construction methods, in a vessel that size.
Old 05-06-2007, 07:54 AM
nautical's Avatar
Rep: 10 Posts: 73
well that didnt help much, but thanks for the reply
Old 05-07-2007, 03:07 AM
All construction methods have advantages and disadvantages. No particular method is more valid than another, without some sort of qualifier. Is there something specific you'd like to know?
Old 05-07-2007, 08:41 AM
nautical's Avatar
Rep: 10 Posts: 73
ok let me change the question. say I want more knowlage about the method. and i only have access to 20 years old books. and i am sure most glues epoxies have changed.
Old 05-07-2007, 09:39 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 302 Posts: 2,319
For a 30m vessel global stiffness becomes more important than in smaller vessels at say 10m. For longitudinal stiffness you may want to read about strip-planking, but steel or aluminium is more common choices for this size.
To get answers here it's better to be more specific, and also try the search button first :-9
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 05-08-2007, 12:06 AM
Cold molding still relies on the same principles, it did 20 years ago. 'Glass boats have experienced changes in the resin used by some manufactures, but the principles are the same. I know of a 130' cold molded hull and a 120' strip planked hull, both turned out to be fine examples of their type, but equally could have been lighter and less costly in metal. Dave Geer's book "Elements of Boat Strength" can bring you up to speed on some of these methods, as well as the technical details of sizing the individual pieces, that make up the vessel. There are several good books on both subjects. Try a search in the BoatDesign.net book store or your favorite book seller.
Old 05-08-2007, 06:25 PM
nautical's Avatar
Rep: 10 Posts: 73
Thanks again PAR i will sure find that book very soon. I checked our library and I didnt find the book or found some books on plywood boat building. Sure I will get that book oneday.
And Raggi I cant be very specific be becuse I am just starting this. But to be more specific I am more curious about the sheathing. (fiberglass covering) If i am right.
Old 05-08-2007, 06:30 PM
Raggi_Thor's Avatar
OK,
I think PAR is right, over a certain size metal will be lighter (and cheaper) than glass or wood.
www.MBOATS.no
Old 05-09-2007, 11:30 PM
I'm not trying to be coy Nautical. It's a complicated subject, covering several engineering disciplines. This isn't the best format to gain a reasonable understanding of the concepts, principles and engineering fundamentals on the topics you desire.
In other words, I could offer a several thousand word explanation on the subject and you'd still have questions.
If interested in books, try http://www.addall.com/, which is All Book Search. Type in the subject you want and you'll find many hits. I typed in the word "fiberglass" and got 17 books.
Old 05-10-2007, 12:59 AM
nautical's Avatar
Rep: 10 Posts: 73
Thanks par. you have been very helpful. I have collected a few books and got the dave gerrs book too. very nicely explained.
Old 05-10-2007, 10:25 AM
frosh's Avatar
frosh frosh is offline
Rep: 44 Posts: 621
Is your question appropriate?
Nautical, with all due respect, I don't think it is at all wise to be considering building a 30m vessel, and asking Forum Members for opinions on the best construction method. Really! 30 meters long and you are not consulting with a top Naval Architect about this vital detail. You have got to be joking!
Am I off the topic yet?
Old 05-10-2007, 01:28 PM
nautical's Avatar
Rep: 10 Posts: 73
frosh. you are wrong I am not asking anyone for the best construction method. I asked for some pro and cons. and asked for some sources. And there are top naval architects here ? this forum is not all about amature boat builders and some of them can be really helpful. (btw I have talked to Naval Architects abt this)
Old 05-10-2007, 06:02 PM
Raggi_Thor's Avatar
Nautical, do you have a name?
I agree with you, we discuss everything, just out of curiosity.
If you are going to build a 30 meter boat there are a lot of other questions also, like time and money :-)
www.MBOATS.no
Old 05-10-2007, 06:38 PM
nautical's Avatar
Rep: 10 Posts: 73
Raggi Thor I am very aware of those things. I am not building anything yet or maybe not anytime soon. I am learning
Cold-moulding vs. Fiberglass sheathing Chris Merriam Wooden Boat Building and Restoration 26 10-31-2007 04:56 AM
The Latest "Skinny" on Cold-Moulding mcm Wooden Boat Building and Restoration 16 11-14-2006 10:10 PM
help with fiber glass stranger2u62090 Materials 0 02-15-2006 05:43 AM
Weight of fiber glass jfblouin Fiberglass and Composite Boat Building 10 07-14-2005 11:30 AM
How do I build a mast out of Carbon Fiber or glass Lowcarb Boatbuilding 30 09-27-2004 11:09 AM
