Old 01-16-2005, 11:13 AM
Richard Petersen
That is a possibility. But I want to finish the boat before I die. I have picked a design that has no sharp curves. I should be able with neighbors help, and 1" closed cell poly foam to draw the single layer of ply around the frames with choker ropes and a few light duty comealongs. Not to distort, but enough to allow equal left and right side assy. It worked on a 8' PTB. Why not on a 17.5'-- 2 seater? I will overpower the daylight out of it if need be. 389 ft lbs of torque from 1000 rpm up. Ease of assy., ONCE, is the very attainable goal. A couple of clear coats. Poof, I am in the water. THEN I can decide if I really love her. And lavish money on her.
Old 01-16-2005, 11:24 AM
Richard Petersen
Lived in Metuchen, next to Fords. I will use either Condons out of White Plains, NY, Shipping is my problem.. Or Harbor out of Baltimore, MD. They deliver no charge to NJ. Or maybe Lumber Products thru local Reps. www.lumpro.com , they have AA FIR 4' X 18'. Phoning them on Tuesday.I am not getting enough sleep since I am doing this boat for real.
Old 01-16-2005, 11:39 AM
Richard Petersen
Veneer over FIR can be very risky due to FIR being a very strong grained wood. It can check so strongly, that it would easely check right thru epoxy alone and the veneer if it had to. AA shoud not do that, but. I would have a seizure and look for a gas pipe. Bruynzeel should spare me. Rich
caulking advice jools Materials 6 10-26-2006 05:47 AM
Using double layers of marine ply cat28 Materials 5 07-05-2005 12:26 PM
fibreglassing work advice solcatbrothers Sailboats 3 11-25-2004 07:39 PM
Molding pulling away Logan1500 Powerboats 1 05-24-2004 05:20 AM
cold galvanized floors Boatbuilding 3 02-16-2003 03:31 PM
