Old 09-05-2006, 11:23 AM
byankee byankee is offline
Rep: 14 Posts: 47
Cherry - useful boat wood?
Can anyone tell me why cherry is not used more often in boat building? It seems to me that it might be an attractive and reasonable substitue for mahogany in may applications - but I've been wrong about these things before. It is strong, stable (nearly as stable as Honduras Mahogany) very durable, better stiffness and bending strength than mahogany and a bit lighter. What am I missing?
Old 09-05-2006, 12:00 PM
Toot Toot is offline
Rep: 17 Posts: 274
I'd guess it has something to do with the lack of large sizes available and the amount that is out there. With that said though, any wood can be substituted for another if you take care to account for its deficiencies.
Are we off-topic yet?
Old 09-05-2006, 12:19 PM
Crag Cay Crag Cay is offline
Rep: 572 Posts: 635
North American Cherry (Prunus serotina) seems to be a very popular wood for boat interiors at the moment. You can get faced ply panels, veneers and solid wood.
I offer it as an option on all interiors partly as a reaction to the dodgy sourcing of some tropical hardwoods, and partly because it makes for a lighter feel below decks.
If anyone visits Tatton Park House in Cheshire, take a look at the dining table by Gillows of Lancaster. I think it seats 26 or so. Can't see the joins? It's made from single peice of mahogany and the off cut was used for the sideboard, which in itself is the size of a small car. It's been a while since mahogany of that size has appeared in any wood yard I have visited over the last number of years.
Old 09-08-2006, 03:18 PM
chandler chandler is offline
Rep: 16 Posts: 378
I would guess that cherry is not very rot resistant, as well as not readily available. You don't see many large cherry trees growing on the side of the road ,and you don't see any growing in the wild.
Old 09-08-2006, 04:29 PM
Rep: 572 Posts: 635
Cherry grows throughout the eastern USA from Florida up to the border and into Ontario, but mainly in the commercial forestry areas of Penn, New York, Tennessee, etc. Trees live up to 200 years and Cherry timber makes up five percent of all the USA's hardwood production.
It is readily available, with excellent working properties, glues well and is stable. The heartwood is rated as 'durable'.
Specific Gravity: 0.50 (12% M.C.)
Average Weight: 561 kg/m3 (12% M.C.)
Average Volumetric Shrinkage: 9.2% (Green to 6% M.C.)
Modulus of Elasticity: 10,274 MPa
Hardness: 4226 N
I guess traditionally there have been other woods for the structure of a boat, but I rate cherry for boat interiors.
Old 09-08-2006, 04:41 PM
timgoz's Avatar
timgoz timgoz is offline
Rep: 262 Posts: 1,067
Here in the southwest of PA we do have some Cherry in the wild. Alot of it is used as firewood here.
They (?) say that SW PA has more types of decideuos trees & bushes than anywhere in the world except possibly a forest in China.
Makes for a beautiful Fall.
Take care.
TGoz
Old 09-10-2006, 08:57 AM
LP's Avatar
LP LP is offline
Rep: 385 Posts: 671
I think the final question that needs to be answered is, "What is it's natural resistance to rot?"
Interiors aren't subjected to continuous moisture and so just about any wood you want can be used there, but if you're looking at a structural application with continual exposure to moisture, you may want to stick with a more traditionally accepted wood that has been proven to work in your particular application.
Construction technique may come in to play, too. Epoxy encapsulation may allow your to use a lesser quality wood (in this case, due to a possibility of less resistance to rot).
LP
God bless the open minded people of the world. LP
Old 09-18-2006, 05:33 PM
bntii's Avatar
bntii bntii is offline
Rep: 1073 Posts: 704
Cherry is fine for interiors- beautiful in fact.
Outside it will check to toothpicks in a short time.
Old 03-23-2007, 03:32 PM
TerryKing's Avatar
TerryKing TerryKing is offline
On the Red Sea!
Rep: 278 Posts: 581
Location: King Abdullah University of Science & Technology - Near Jeddah, Saudi Arabia
Where does this information come from??
The US Forest Products "Wood Handbook- Wood as en Engineering Material" says Cherry is quite far up in Rot Resistance, but not as good as Mahogany. **UPDATE** The Forest Service Laboratory's detailed Tech Sheet says, "The strength properties of mahogany are generally similar to those of paper birch and black cherry."
UPDATE: No, I found I have the whole book saved in a computer archive! Hardwood is rated in three categories, and I will put just a few examples as the table is large: (Sorry can't make a real table here, right??)
Resistant or very resistant
cedar
cherry
chestnut
cypress
old growth teak
white oak
black walnut
american mahogany
Moderately resistant
douglas fir
pines
redwood
new growth teak
african mahogany
Slightly or nonresistant
ash
birch
beech
maple
Can anyone point to a Marine-specific rating of wood species, for rot, toughness, abrasion etc??
I'm thinking of using Cherry for some repairs, as I have it on hand...
Regards, Terry King ...On the Red Sea at KAUST
Old 03-23-2007, 05:09 PM
bntii's Avatar
"WHERE DOES THIS INFORMATION COME FROM?"
Years of experience as ships carpenter and all around great guy
One should note the difference between rot resistance and the ability to resist weathering.
Mahogany will go to pieces if left bright too long cherry much more so... I would not put time and effort into building anything for the exterior of a boat out of cherry
Old 03-23-2007, 10:10 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
What is the nature of the repair? Speaking of familiar American woods...Cherry (or any fruit wood) makes a good interior wood. White oak and hard resinous pines make good framing stock; cedar, mahogany, and white pine for planking.
Each marine wood has characteristics that favor certain special conditions. White oak is prone to checking unless carefully sealed if it is used for brightwork, but it is amazingly tough and it steams beautifully, so I'm using it on my coamings and some brightwork. If I were painting the same pieces, I would use the same wood because it is a bargain compared to mahogany.
Cedar (red, white, atlantic) make good plank stock because cedar has great "memory", which is to say it can be compressed due to water absorbtion and come back smiling.
Some woods, like cedar, do not hold fasteners very well, like oak or honduras mahogany do.
I've heard that walnut is a good rot resistent wood. I used it for parrels on my gaff rig. I wouldn't hestate to use it for gaff and boom jaws, painted or bright. I would even use it for deck frames except white oak is so much cheaper. I would also use fir for my deck frames, but not for gaff jaws (mine are white oak). Fir is not as tough as walnut or oak, but it's lighter and strong for its weight, and it won't easily rot.
Phillipine mahogany isn't bad for planking stock provided it's vertical grain. Chris Craft used it for years, and it seems to hold up well, probably because of the way it was milled.
Never use maple, birch, poplar, or beech on a boat. Redwood is supposed to be rot-resisent, but it's weak and brittle. Use ash selectively---- tiller, interior, any place where it can stay dry or you can see every side of it.
Alan
Old 03-23-2007, 10:37 PM
Rep: 14 Posts: 47
I was wondering if cherry would be a reasonable substitute for the traditional apple crooks used for knees and such, Any thoughts?
Old 03-23-2007, 10:46 PM
Rep: 505 Posts: 1,637
what do you mean ( mahogony will go to pieces if left brite too long?),,,I owned on boat that was over 100 yrs old ,made of mahogony,,an open skiff,longliner
Old 03-24-2007, 01:08 AM
Rep: 3125 Posts: 9,403
Prunus serotina (black cherry), The genus Prunus includes the apricot, almond, cherry, plum and peach.
Cherry is brittle and typically used in furniture, interior trim and decorative applications only, though I have seen some healthy chunks of it used as knees, which I thought was a poor material selection at the time. It's so brittle in fact, that substantial limbs of live trees will fall off in moderate wind storms (much more so then other trees). It is hated and religiously cut down by farmers, because the frequently dropped limbs release cyanide as it decays, which threatens livestock and crops. I couldn't recommend it as a structural element, but it is a beautiful wood and certainly has a places for use.
Old 03-24-2007, 04:25 AM
TerryKing's Avatar
On the Red Sea!
Rep: 278 Posts: 581
Wood Species for Marine Applications
Well, there certainly is a lot to learn about this subject, and some varying opinions and experiences. The Wood Handbook I mentioned is based on a lot of research and experience, but it doesn't directly address the Marine environment except in a few places.
Maybe we/somebody could start a MATERIALS page on the Wiki http://www.boatdesign.net/wiki
Can anyone point to a book etc. that has a list of wood species (and maybe other materials) specifically rated for Marine Applications?? I didn't find a good reference in a quick Google search.. Some of you guys must have good book on the shelf.
I'm going to run one test starting in May when I get back to the US: I'm going to make two exposed porch rails out of Cherry, with two different finishes - one Marine Varnish and one Oil-Beeswax based. I'll track it over the next few years. I'll do that mainly because I have lumber from my property there in Vermont. I also have birch,ash,maple and beech lumber that I cut and dried about 5 years ago, but none of those species are rated well for anything exterior as far as I can see..
I used local Cedar (from a local mill) for the interior ribs and frame of the replacement cabin I put on Expedition about 3 years ago, and it worked well and looks great inside in that protected application.
More to learn!
Domestic cherry deck planking? FRPWoody Wooden Boat Building and Restoration 6 08-13-2005 12:47 AM
Cherry Update, First regatta WildCherry Sailboats 1 07-13-2005 05:29 AM
The Cherry project continues WildCherry Sailboats 14 05-31-2005 09:35 AM
Cherry is Complete WildCherry Sailboats 2 05-26-2005 01:54 PM
Wood boat Insurance alanagr1 Open Discussion: All Things Boats & Boating 2 05-29-2004 06:16 PM
