| Just keep in mind that you are trusting your life to this contraption...inspect it before each use and make sure it will stay together, use a pfd and glue some foam under the seats and anywhere else you can where it is out of the way. Treat it like it might fall apart at any time and it probably won't. |
| Cheap epoxy, any reason why it won't work for laminating? | LundieF | Fiberglass and Composite Boat Building | 11 | 12-15-2010 10:45 AM |
| System Three Epoxy Resin and Hardener #3 FOR SALE CHEAP | CatBuilder | Marketplace | 3 | 09-29-2010 12:28 PM |
| Alternative to Fiberglass and Epoxy? | BIFFTHESKIFF | Fiberglass and Composite Boat Building | 9 | 06-29-2009 02:11 PM |
| Are there any good cheap epoxy resins? | Texas-Tri | Materials | 26 | 08-01-2008 02:11 PM |
| small fiberglass hydroplane molds CHEAP | mitchblack | Fiberglass and Composite Boat Building | 5 | 05-30-2006 12:03 PM |
