| Chainplate fastenings Don't you just feel sometimes you have a dragon by the tail? I am preping my (re-stripplanked to above waterline) 34' sailboat to glass with a 30oz triaxial.The frames and floors will be removed and it will be glassed inside as well and a reduced frame/floor configuration glassed into the hull structure. Don't ask me why I chose to do this, I just am! I am followingTom MacN. scantlings. On removing the chain bolts from their epoxy seats in the timber they turned out to be 3/8" what looked to be brass in SS 2 x 3/8 straps. I am inclined to replace with 1/2" 316 SS. Is this appropriate? There are three for cap shroud,three for the aft lower and three for the frwd lower. Inside they are all connect by a 6"x2"x6' chain plank and three more bolts through frames. I am removing the chainplank (because of the glass) and will have a laminated frame tabbed to the hull for each of the shrouds. Any comments appreciated. |
| I'm a bit leery of stainless steel in situations like this. A stainless bolt, put through a wood beam and embedded in epoxy, is in a highly anaerobic environment and will be quite prone to corrosion if any water gets trapped in there. Brass, due to its zinc content, is also rather poor in these conditions. What's corrosion resistant and has a high tensile strength.... perhaps someone with more wooden-boat experience will weigh in?
Steve |
| The chain plates are stainless and 316 is the easiest option, so guess I will run with that.( Bearing in mind the risk of crevice corrosion) Thanks for the info. |
| Chainplate alignment | Lunde | Wooden Boat Building and Restoration | 2 | 10-16-2005 02:29 PM |
| Replacing chainplate structure - keelboat | RickEdmonds | Boat Design | 3 | 07-22-2004 09:24 PM |
| chainplate design | 66jwa | Boat Design | 7 | 05-08-2004 12:46 AM |
| Chainplate location | Overdraft | Sailboats | 8 | 03-31-2004 01:53 AM |
