| caulking hi i have a 65ft oak on oak trawler carvel construction does anyone know or done a re caulk between tides |
| I did a recaulk on a 34ft. Fishing boat. Trawler style. I could never have done it between tides. If you have a good crew you might do it. 65 ft is a lot of caulking. Are you using cotton or oakum? |
| thanks lancerbye the way i was thinkingof doing this is maybe one seam at a time just rake out enough to replace between tides i will use oakum but need a fairing compound that will adhere to wet timber |
| The union says a caulker does 15 feet of seam an hour. It looks like it may take a lot of tides for a boat that size. I know haulouts can be costly but for some reason, doing caulking between tides doesn't sound like fun. I have never tried it, though, so give it a try and see how it goes. |
| Gilbert's time sounds about right. Have you got your rakes made and your caulking irons in good shape. The hardest seam is the first one along the keel and your fairing compound for that one is often times a flex mortor type of compound which will cure under water. For the rest I had used a two part paraseal which cures quickly and sticks to any and everything. The effect of this is a flexable seam but the caravel plank style is very visable which is nice to look at but some like to hide this effect. They would use red lead or a flex mortor whose name escapes me at the present time.The problem with those is any flex in your vessel will show up as cracks in the paint job. I am sure there is new stuff on the market that would work well. I last did this back in 1985. good luck. |
| caulking Cliche - but in this case true: Time and tide etc. haul her up on the hard and allow at least three days. A rushed caulking job is a waste of time and effort. Take your time, clean the seams thoroughly (look out for previously used short-cuts - putty etc) lay in the new oakum/cotton dipped in a thin coat of pitch and pound home. Add redlead 'to taste' (but wear gloves and mask) allow at least a day to dry - then slap on a couple of coats of paint. |
| http://www.tradboats.com/conseamfillers.html There's a product on here called black pudding...not used it myself but its said to be the stuff for between tides. |
| caulking Quote:
Lawks O mussy. You'll be caulking with haggis next... ![]() |
| thanks everyone i think its haul out time does anyone know of a good caulker around the southampton area |
| caulking planks | JimHog | Wooden Boat Building and Restoration | 35 | 08-09-2011 12:46 AM |
| caulking advice | jools | Materials | 6 | 10-26-2006 06:47 AM |
| New Here....Need Advice On Caulking | Bob Smalser | Boatbuilding | 9 | 07-09-2006 04:37 AM |
| corking? caulking? help | Dave Van Domele | Wooden Boat Building and Restoration | 15 | 06-16-2006 09:34 PM |
| caulking alternatives | 8knots | Materials | 9 | 12-12-2003 01:20 AM |
