| Building a wooden boat I want to build a boat.I'm building the heckle off of clarkecraft.com its a runabout sport. What wood do I use for the structure. Instead of using an inboard drive could I use a jet drive? Please help. Building tips would be great. |
| First read some books, surf the net and look at different stock designs, buy some plans from a designer that also can advice on materials etc. You can build a traditional wooden boat or you can use wood as a strctural fibre encapsulated in epoxy or you can use plywood skin over a wood structure... OK, I see that Clark Craft tell you most of this. http://www.clarkcraft.com/confram.ph...tem=1102635816 What does "heckle off" mean? |
| Is this the one? Heckle 9? http://www.clarkcraft.com/cgi-local/...17046f890b9f91 |
| TP52s | mighetto | Sailboats | 2052 | 09-06-2007 11:46 AM |
| Wooden boat builders - HELP! | Converted | Wooden Boat Building and Restoration | 7 | 09-20-2006 11:59 PM |
| High-Speed Waveless Boat | waveless | Boat Design | 82 | 10-10-2005 08:01 AM |
| Has anyone here started a boat building business from scratch? | aqualoco | Fiberglass and Composite Boat Building | 61 | 09-27-2005 01:18 PM |
| Building my first boat. | ihallenius | Boat Design | 18 | 08-03-2005 02:02 AM |
