| Building a hybrid This boat is going to combine a lot of things from different style boats and I hope I will come out with the perfect river fishing and camping boat. It will be a three panel like a perow for running shallow, have enclosed decks like a yak , big open cockpit like a canoe, be strip built but hard chined and a few more things as iI get started on her. Here we go Got a little done to the boat today ![]() This boat is going to be long and skinny I found some cedar 2 bye 6 so I am building the bottom and side panel out of strips 1 1/2 inches wide. Works pretty good so far ![]() This may be old hat to some but might help some of the new guys ,first I laid out my widths every 12 inches ,then drove a nail into the wood as I measured. ![]() then I took a strip and bent it around the curve clamping it and then marking out the panel so it can be cut. ![]() More later Ron |
| Got a little more done to the boat today, I sawed out the bottom leaving a little outside the line and tomorrow I will go back and take a belt sander and bring it into the line. ![]() ![]() I laid up the curve for the side panel and glued one of them up today. I like the strip stitch and glue more each time I use it. ![]() Ron |
| I measured out the lines on the side panel ![]() Having the bottom straight edge sure helps Drove the nails in for my lines ![]() Then the ole strip to mark the curve. ![]() When I finished marking out the panel I moved the bottom marking strip up and fitted it to the contours of the panel I had built. |
![]() Then pulled the first panel and built the second one with out having to measure again. ![]() aftyer these dry I will cut the first panel then just lay it on top of this one to mark it. Ron |
| Got everything cut shaped and sanded today ![]() I wet the bottom out for a look see at the color in the wood ![]() sides wet out ![]() I like This might be my prettiest boat yet, Ron |
| I like it, so far. Eager to see more.
| Finally got threw sanding cut my forms and started stitching her up ![]() Those straight edges on the strips sure go together good. ![]() she is long and lean ,I think she is going to be a keeper. ![]() I will finish stiching her tomorrow and start running some fillets. Ron |
| Got the filets done on the bottom and flipped her over she is starting to look like a boat ![]() Ron |
| Thanks for sharing! nice........... |
| I am going to make one change from Geralds plans, The front deck will be 5 ft and the rear one will be 4 ft. I like to carry an extra paddle and several more things that are long and light. Got the front and rear bulkheads glued up ![]() Started gluing the shear strips on. ![]() I am going to be waiting on epoxy and cloth if it doesnt hurry up and come in. Ron |
| Top decks will be1/4+ 3/4 white pine and wrc Strips laid out and glued ![]() ![]() Top of decks sanded ![]() ![]() The bulkhead as one coat of glass on it ,I think it will be a pretty l. Ron |
| Got the inside filets done ![]() Then flipped her over and started sanding and shaping the edges, ![]() Sicking up pretty good with a little luck saturation coat tomorrow. Ron |
| Got a saturation coat on the outside of the hull ![]() ![]() ![]() I think it will look pretty sharp. Ron |
| Got the glass cloth put on the BNN today ,dang epoxy is worse than watching paint dry ![]() ![]() Ron |
| Got the glass trimmed and flipped her over. Started applying the saturation coat to the inside. ![]() ![]() Ron |
| Hybrid Sportfish | Corpus Skipper | Powerboats | 23 | 06-14-2008 04:29 PM |
| Hybrid Boat | peetgr | Open Discussion: All Things Boats & Boating | 13 | 11-13-2007 03:14 PM |
| hybrid | Cheesecutter | Hybrid | 4 | 12-06-2006 03:06 AM |
| Hybrid sailboat | prp25brad | Propulsion | 2 | 04-02-2005 08:29 PM |
| hybrid pwc | h2o | Boat Design | 1 | 09-13-2004 01:01 PM |
