troy2000
- Joined
- Nov 3, 2009
- Posts
- 1,738
- Reaction score
- 170
- Location
- California
I'm building a canoe with my younger son as a summer project, before he goes into the Army this fall.
Warning: following the steps and procedures in this thread is no guarantee of success, and your experience and results may vary markedly from those shown below.
Step 1: go get some wood.
You don't need much; 32 feet of 1 x 12 will do the sides, and 1 sheet of 3/8" plywood will do the bottom. For the frames, stem, transom and miscellaneous, we're using stuff we have laying around. Of course, we probably have more stuff laying around than the average city dweller would....
The sides will be pine. It would be nice to do the Cajun thing and use cypress, but this is California. For what it would cost me to run down cypress boards, I could probably migrate to Louisiana, buy a house, and have enought left over for the cypress. Since the canoe will spend most of its life upside down on a pair of sawhorses anyway, I think the pine will do fine as long it's kept painted.
We bought two 12-footers and an 8-footer, because no one in this area stocks 16-foot 1 x 12's. That means we'll be scarphing 4 feet onto the stern end of each side. For the bottom we picked up a sheet of 3/8" BC pine; it was only about twenty bucks.
Step 2: prepare the worksite, and collect your tools.
All my tools were behind the rental on the opposite corner of our place, where my parents and nephew used to live. Unfortunately, there's no power there right now. So the new workshop became a shade tree we could reach with power cords from our house.
Why there? Because that's about where the two of us ran out of steam, while moving my 400-lb thickness planer. In the middle of taking a breather we looked around and said, 'you know what? There's shade here....'
Step 3: make sure you have a reliable power source.
Step 4: plane the side planks to make the boat lighter, and make them easier to bend. We took them down from 3/4" to 9/16", and decided not to push our luck any farther.
The plank leaning to the left is an old piece of red oak. We ran it through a few times to make sure the planer still worked, and to shake some dust and rust off the blades. I was also thinking of using it to make the transom, but it turned out some bugs were already using it for a home. Ah well, it would've added weight anyway.
Step 5: well, there really hasn't been one yet. We moved a work table, table saw, jointer, power miter saw and some miscellaneous tools under the trees. I started making a jig so we could cut the scarfs with a router, but ran out of daylight and ambition at about the same time.
