Old 10-06-2005, 08:49 PM
corkhopper's Avatar
corkhopper corkhopper is offline
Rep: 10 Posts: 7
Brackish water
I have purchased a mahoganny on oak boat and will be introducing her into salt water in the end of the month. Currently the boat sits on the Thames in fresh/brackish water. I have read on another website forum that fresh and/or brackish water is particularly bad for mahoganny boats. Is this correct? If so, what steps should I take to re-introduce her to salt water. I believe she has been in fresh/brackish water for ten years of the last 70.
Thanks
Old 10-07-2005, 04:58 PM
cyclops cyclops is offline
Rep: 29 Posts: 1,059
Take it out and look at EVERY piece of metal that is on the bottom or goes thru the bottom. Then yank very hard on every part inside and outside to see if it snaps off.------Wood guys are next.
Old 10-07-2005, 08:27 PM
corkhopper's Avatar
Rep: 10 Posts: 7
Thank you, cyclops, for your advise. I will check her thoroughly.
Auto engine marinization DIY Marinizing 231 07-01-2010 08:34 PM
epoxy fuel tanks Boatbuilding 24 08-14-2008 04:36 AM
Wakes... marshmat Open Discussion: All Things Boats & Boating 19 01-07-2006 05:51 PM
Building a heat exchanger into the hull djackson99 Powerboats 42 03-21-2005 03:15 PM
