Old 05-24-2011, 07:55 PM
Rep: 1493 Posts: 7,447
The bi-color ones are not legal. In the USA they are manufactured with a horizontal filament bulb. From straight ahead the light shows orange.
Old 05-25-2011, 05:27 AM
keysdisease's Avatar
keysdisease keysdisease is offline
Rep: 205 Posts: 442
To meet the international 72 Colregs there is a pretty precise requirement for range and arcs of visibility. Range is 2 miles. There is an allowable "bleed over" beyond the arcs but it is so small that manufacturers that meet the spec were required to source vertical filament bulbs.
The spec is 112.5 degrees for red and same for green totaling 225 degrees forward. The cutoff between the red and green is very precise so when seen from forward the light changes from red to green.
It is unfortunate because these bulbs have a pretty short lifespan because of the filament configuration.
There are tons of cheap "knockoff" lights that use the standard automotive bayonet type bulbs, none are "legal."
Originally Posted by stevelima View Post
My question is what is the differance between these lights and mine. I'm sure learning alot about lights from you guys. thank you. Tha one I followed was the Bow bi color.
Old 05-25-2011, 05:35 AM
Rep: 205 Posts: 442
As a side note the arcs of visibility apply to the vertical plane too. Thats where you will see "glare shields" or reduced glare lights that have bottom cutoffs to keep the light off the deck and reduce glare that kills night vision.
I'm conviced an eskimo style upswept split bow acts like a bulbous bow, but Squidly-Diddly Boat Design 4 08-23-2009 06:08 PM
Ies Lights And Nav Lights In Rhino Sean Herron Software 2 02-01-2008 09:09 PM
3 prong lights going coastal OnBoard Electronics & Controls 6 05-13-2007 10:10 AM
Planing bow hull and getting over the bow wave hump kach22i Boat Design 2 04-03-2007 03:51 PM
The buoyant bow and bow steering in heavy weather kach22i Boat Design 8 01-06-2007 05:13 AM
