Old 09-11-2005, 05:24 PM
Lunde Lunde is offline
Rep: 10 Posts: 9
bonding to wooden hull
Hey! I am just starting on the interior on a newly built wooden hull, and I am just wondering if it is absolutely common to bond cleats and plywood, when making all the interior stuff, to the actual hull, the planks?Because if and when a plank must be replaced everything that is bonded to it must go...I know that all bulkheads should not touch the planks, because of structure damage, but apparently it should still be bonded with epoxy and cloth,- as my planks run the boats length without cuts, I can only imagine the amount of pieces of furniture it would affect if a plank has to be removed.....please HELP!
Old 09-11-2005, 09:55 PM
LP's Avatar
LP LP is offline
Rep: 370 Posts: 641
Interiors
What kind of constuction is it? Are there frames? Are there floors? Is there a cabin sole? Unless interior bulkheads are structural, they should be removeable as with all interior joinery. There are designs where interior furniture is part of the structure, but from the nature of your questions, this is not the case. You may not have much choice but to apply cleats to the hull. I would use the cleats on the cabin sole and under decks and use frames before using the hull directly. Then screw attach the furnishings to the cleats to make it removeable. Depending on the size of the boat, you could ceil over the frames, if there are any, and attach the cleats to the ceiling.
Good luck.
LP
God bless the open minded people of the world. LP
Old 09-13-2005, 10:21 AM
Rep: 1397 Posts: 7,216
Structural bulkheads must be bonded or fastened to the hull. What do you mean they don't touch?
Old 09-14-2005, 03:35 AM
Rep: 10 Posts: 9
My boat has wooden frames, only about 6 inches between each one.I ougth to be able avoid fastening to the planks.Structural bulkheads, I am told, should be half an inch from the hull, and fastened to the frames and to the planks with epoxy and cloth...is it bullocks?
Another solution I have to come up with, is the placing of the sole.In my case, I have to access the bilge , not from the center of the bilge, but from the sides, because of a continous maststep that goes all along the bilge.
So, is it possible,( and how!?) for me to fasten, for example a settee, not to the sole, but to the frames, using the frames as a horisontal base for the settee.This way I could make the sole completely so it can be lifted, and access the bilge.
I mean, ´how important is it to have access all along the bilge, from aft to fore?I could also just have access 6 ft for example.
Old 09-16-2005, 08:48 AM
LP's Avatar
LP LP is offline
Rep: 370 Posts: 641
furniture
Lunde,
Need more information on your boat.
How big is your boat? (Length overall, waterline length, max. beam and waterline beam)
What type of construction is it? (Traditional carvel or lapstrake, modern epoxy strip-built, cold-molded, lapstrake or stitch and glue)
LP
Hull speed Mike D Boat Design 33 02-27-2011 02:20 AM
Jet Drive Jet Drives 15 12-18-2006 10:51 AM
