| Bonding material Hello everyone, I am building a small wood boat with a Yamaha jetski engine and pump drive. I cut the bottom of the jetski hull out to fit into the bottom of my boat. I am trying to find a good bonding material that will help seal and bond the fiberglass jetski hull to the bottom of my plywood boat. It will be screwed in place also so the material will be more of a sealer than a bonder. I am looking for stuff that is like what the jetski manufactures use to bond their hulls together. If any of you have seen this stuff, it is REAL strong, but stays semi rigid. It does not dry hard and brittle, but it is harder than just window caulk. Anyone got any suggestions on what I can use and where to get it? Thanks, Tony |
| My guess would be a 3M Polyurethane Adhesive such as 3M 560 ( Scotch-Seal) or similar.
__________________ Yours Aye! Rick M/V She:Kon Blog ~^~^~^^~^~^~^~^~^~^~^~~^~^~~^~^~^^~~^~^ "It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up! |
| Ok, Thanks. I will check into it. |
| We use Cray Valley "Thixo Iso UPE1254" bonding paste to join GRP decks to hulls. Immensely strong join when cured.
| Epoxy, epoxy, epoxy. You don't want a sealant, you want to bond it solidly. Epoxy and fabric, preferably biax. |
| electrical bonding... | EMBIBB | OnBoard Electronics & Controls | 5 | 12-20-2007 02:01 PM |
| lexan bonding | GVQ | Materials | 14 | 10-12-2005 07:44 AM |
| boat material / furniture material | bogeyinthekeys | Materials | 7 | 09-10-2005 09:29 AM |
| Bonding windows in trawler | Scratchy Dan | Boat Design | 9 | 11-14-2004 10:19 AM |
| Need help for bonding options | rum2001uk | Wooden Boat Building and Restoration | 7 | 09-10-2004 07:20 PM |
