| bolting in my quarter knee I am restoring a wooden boat. I still have to put the plywood and fiber glass. Should i bolt the quarter knee to the transom and keel right away or wait till i fiber glass it first? |
| Glass first for speed. You shouldn't need to use bolts if you glass it in, but if you are bolting, no sense also glassing the knee in. Glassing inside the boat isn't really necessary with plywood either, except at the seams. Sounds like you're mixing methods? |
| maybe i was not clear on my first post or maybe i am combining two methods. When i took the boat apart there was fiberglass on the outside and all the quarter knees were bolted so i assumed both were needed. My plans were to scarf all the plywood screw it on where the rub rails will cover it and nail with ring nails then fiberglass the outside then bolt the quarterknees. |
| I misunderstood. From what little you've written, the answer is, you bury the screws and bolts under the glass. I'm assuming they aren't bolts but flat head machine screws. Or should be. Putty the heads and glass right over them. You want to ensure the bottom is watertight. |
| Transom knee´s and their position | Dragonsailor | Fiberglass and Composite Boat Building | 5 | 05-07-2010 01:19 AM |
| Bolting Chainplate On Bulkhead | DUCRUY Jacques | Class Societies | 8 | 12-22-2009 05:00 AM |
| Quarter Ton Design Rule | RichR | Boat Design | 24 | 05-27-2009 09:39 AM |
| Restoring a Quarter Ton | D'ARTOIS | Wooden Boat Building and Restoration | 12 | 09-13-2006 05:31 PM |
| Arrrr! No Quarter! | Thunderhead19 | Open Discussion: All Things Boats & Boating | 41 | 03-18-2006 07:50 AM |
