| BoaT Plans _______ Last edited by pcwebster : 07-19-2009 at 09:16 PM. Reason: _____ |
| Those plans already exist, obviously. Why not use those? |
| plans ______ Last edited by pcwebster : 07-19-2009 at 09:16 PM. Reason: done |
| Okay, but how do you propose someone here could repeat that boat unless only recreating something that looks, but does not perform like the photos? Or if the boat itself exists, could you take lines off of it? |
| Would this design fit the bill: https://www.boatdesigns.com/products.asp?dept=221 If you plan to build the boat, you should be able to afford a set of plans as well. |
| boat plans _______ Last edited by pcwebster : 07-19-2009 at 09:16 PM. Reason: done |
| Are you saying you wisdh to hire someone here to draw plans for a boat that looks just like the one in the picture you posted? |
| Yes, I can draw those plans for you, but frankly, it would be a lot cheaper to use the existing plans, which I'm fairly sure are an old Whit or Jackson design. There are lots of these little pocket rocket plans available, is there a specific need for a custom set of plans? |
| plans yes, and I dont know and I can find any that I like and I have some different ideas, thanks |
| It looks like you have two different boats in the pictures, I think the red and white one is a Sanger?? And the frame setup looks like this boat. http://www.boattrader.com/listing/19...-Boat-94484884 BTW, this boat is in Florida, and you can't build it for $8500 with the trailer and all. There are copy rights on these things you know? |
| plans +++++++ Last edited by pcwebster : 07-19-2009 at 09:15 PM. Reason: plans are done |
| Triple keeled boat plans/vs trimaran vs swath boat for stability and searworthiness | blackdaisies | Stability | 4 | 09-28-2008 01:09 PM |
| Boat Plans | elcapitan | Boat Design | 3 | 06-05-2007 03:39 PM |
| boat plans | bazman | Boat Design | 0 | 07-31-2003 08:29 AM |
| Boat Plans | JohnK | Powerboats | 2 | 06-15-2002 04:42 PM |
| Boat Plans | JohnK | Boat Design | 0 | 06-14-2002 01:39 PM |
