Old 01-29-2006, 08:58 PM
64centuryhelp 64centuryhelp is offline
Rep: 10 Posts: 2
Below Water Seams On Wooden Boat
I have a 1964 Century Resorter. I am currently restoring it and have run into a problem. The caulk on the bottom below the water line is falling out and I am not sure what to replace it with. The boat spends most of its time on the trailer. It is rarely in the water. Is there a product that you recommend to fill the seams? The gaps are 1/16th to 3/16th of an inch. I am afraid that swelling will not solve my problem.
Old 02-01-2006, 06:53 AM
wdnboatbuilder's Avatar
wdnboatbuilder wdnboatbuilder is offline
Rep: 15 Posts: 227
I can not believe PAR has not seen this yet. Gonzo maybe some help to you also, these are all members of this forum and have a great amount of info.
Calm days, Tides Running, and Fish Biting
What more could you ask for?
Bruce
Old 02-01-2006, 01:30 PM
Rep: 3125 Posts: 9,403
I saw it Bruce, but my only experience is with a 1967 Resorter, which had a double planked plywood bottom.
I'm concerned with the larger gaps, plywood doesn't move that much, making me think something else is going on (fasteners getting loose, relaxed framing, trailer sickness, etc.)
In direct answer to the goo in the seam question, use a polysulfide like 3M 101 or similar. I wouldn't use 3M 5200 or other polyurethane. I believe the factory used a piece of cotton in the garboard seam before the sealant went in.
Old 02-15-2006, 10:16 PM
BUSBO BUSBO is offline
Rep: 10 Posts: 5
Underwater.
Appart from sussing any unwanted movement;loose or cracked stuff;caulking with cotton soaked in putty&paint.Plywood strip fillets?
I'm no expert and have no idea what the boat is,but heres some stuff I used on a 1" oak planked Walton narrow boat.
Old 02-16-2006, 06:45 AM
Oyster Oyster is offline
Rep: 95 Posts: 240
This shows H2Only hull which he lists as 1964 Century Resorter.
http://boatdesign.net/forums/showthread.php?t=10155
Shown on this hull is longitual planking and battern seamed construction. If indeed this is the same hull that you have here, then and do not wish to replace the caulk, then there are some alternatives here. In the past, simple old timey window putty, mixed with bottom paint has been used, and can be removed later if you need to, too.
There is an Interlux seam compound that is used over cottom caulk on hulls. .
If you can locate Dolphinite Bedding compound, then you can use this product. Have you checked the conditioning of the fasteners? Begin with these examples, but use some of whatever you choose, and the apply a sample to scrap pieces, applying your top finish over it, learning the cure time for painting over it, if this will be a trailable boat. You want to make sure that you do not end up with uncured seam compound and paint and load and unload the boat from the trailer. The stuff will rub off, and pull out, and you will be worse off. Report back on your access of any of these products, and when all else fails, there is a mix that you can make up yourself with hardware store materials, too.
Old 02-16-2006, 12:42 PM
Rep: 10 Posts: 5
Your problem seems to be,that the wood won't get the chance to swell.I suggest clearing out all caulking,then once really clean;applying a flat bede of High Modulus Silicone Sealant 1/16"thick to the bottom of the groove only.After this caulk with some compatible mixture to the finnished surface coating.
Old 02-16-2006, 01:24 PM
Rep: 95 Posts: 240
There is a difference in caulking and corking. Sometimes folks can get these two terms mixed up. But not knowing what is presently falling out, anyone recommending silicone for anything to seal wooden planks up makes me shiver, period. I think this is a general consensous for most folks and has stood the test of time remaining true to form that silicone belongs no where close to wooden bottoms.
Here is a picture of a corked plank. Even with this method, some people will place caulk on top of the cotton which is normally used for corking.
This is a serious restoration project for your viewing pleasure that deals with such an issue.
http://www.kettenburgboats.com/yard6pics10.htm
Old 02-17-2006, 07:42 AM
Rep: 10 Posts: 5
Silicone sealant :nightmare. Indeed not enough info. on project.What falls out can explain a lot. Fair condition:usualy one finds woodlice,ranging thro-earwigs,worms,centerpedes,to beatles boring holes at worst,as they bore through good wood.These beasts can be pointers as to the condition of the wood and presence of rot.
High modulus silicone (Silicone corking...no Shiver me timbers! certainly not a corker!) Any mixes?
Old 02-17-2006, 10:29 AM
H2Only H2Only is offline
Rep: 10 Posts: 25
I am currently in the process of "refreshing" a 64 Resorter. This boat too needed attention to the hull below the waterline. Since this boat is going to be trailered most of it's life also, we decided to glass the hull below the waterline and bottom paint.
Wooden boat builders - HELP! Converted Wooden Boat Building and Restoration 7 09-20-2006 10:59 PM
wooden boat texasboatbuild Wooden Boat Building and Restoration 6 05-09-2006 04:42 PM
Which Wooden Boat Should I Build Rileystargate Open Discussion: All Things Boats & Boating 1 09-24-2004 08:26 AM
Wooden Boat Manufacturing Boatbuilding 3 04-08-2002 11:32 AM
Wooden boat Boatbuilding 1 12-03-2001 12:30 AM
