Old 01-07-2008, 03:11 AM
jesse3474 jesse3474 is offline
Rep: 10 Posts: 4
bad oak ribs in bow
any replys about taking out 12 steamed oak ribs sections 2x3 and replacing with saw cut ash ribs on the bow the rest can sistered. never seen rot on a boat like this, just the bow is rotting, planks, ribs, maybe original fasteners in the bow gone bad, old 40 foot 44 tacoma
Old 01-07-2008, 08:50 AM
alan white's Avatar
Rep: 1211 Posts: 3,325
It's no problem to use sawn frames, but ash isn't a good choice. White oak is the better choice even if you've got a line on some ash. There's enough labor there so the job's not material intensive. White oak (or live oak) will do better in an environment that has already proven to have generated rot. Stay away from red oak--- like ash, it rots readily.
Then get some better air circulation in that area.
Planking replacement should be the same species as the original wood and quarter sawn as well. Alaskan, white, red, and port orford cedars can mix however.
Alan
Old 01-07-2008, 11:18 AM
Rep: 3125 Posts: 9,403
The bow section is a common location for sawn frames, as the shapes usually will permit their use. Sawn frame dimensions should be molded at least 30% more then the steamed ones and sided at least 20% more. Most will use larger dimensions then my minimum recommendations.
Old 01-07-2008, 02:14 PM
Rep: 10 Posts: 4
ash
why not ash, cedar and oak are 4.50 bd ft , im looking at a commericial troller, and thinking of sistering the ribs from the wheel house to the stern, and replacing 30-40 planks, but the bow is tore up bad so figured chainsaw the bow out and go with ash and beam in a bulkhead wall, can i expoxy the ash, orford boat are sawn cut ash frames, is there only one type of ash,
Old 01-07-2008, 02:16 PM
Rep: 10 Posts: 4
ya taking out 2x3 ribs and puting in 4x6 ribs can u use ash,
Old 01-07-2008, 06:45 PM
alan white's Avatar
Epoxy is out in treating the ash, and while some formulas would better preserve ash, the question is why do you not simply use white oak, since it costs only 30% or so more? I pay under $5.00 for white oak.
Google "wood properties" or some such and check out rot resistence of various woods.
Epoxy is a surface coating, a membrane. It penetrates a little bit, but a hardwood especially will check and the membrane is then useless---- and even undesirable, as the wood can become saturated but can't unload the water because it's now sealed in. Pick a wood that can get saturated without rotting easily. Yellow pine, live oak, white oak, etc..
White Oak-Red Oak? Winingar Wooden Boat Building and Restoration 31 04-28-2011 10:01 AM
Planing bow hull and getting over the bow wave hump kach22i Boat Design 2 04-03-2007 03:51 PM
Oak to oak DFV Wooden Boat Building and Restoration 3 01-07-2007 06:09 PM
The buoyant bow and bow steering in heavy weather kach22i Boat Design 8 01-06-2007 05:13 AM
