Old 03-26-2007, 04:36 PM
woodworm woodworm is offline
Rep: 10 Posts: 24
Arcangeli Jolly
Hello from Hamburg in Germany. Sorry about my bad english, replys please in very simple english, otherwise I ll get in troubles.
I ve got an Arcangely Jolly wreck as present.
Nearly every pice of wood was changed in the last 6 weeks. Now the bad job is done and the sides made out of plywood will be replaced.
I will make the plywood only in 4 mm and glue with epoxy mahagonistripes 20 mm x 8 mm on them.
1....- Must I nail them like the old stripbuilding tecnology or is the Plywod epoxy strip enough ?
2....-Is anybody the happy owner of such a little ship.
3....- Is anybody able so show me pictures of the original Interieur of the arcangely Joll 450 outboard version
Best regards
erhard
Old 04-18-2007, 09:57 AM
blackwatch blackwatch is offline
Rep: 10 Posts: 6
Hi,
I m also restoring Arcangly jolly.
Mine is only planked with plywood 6mm thick(no mahogany). Frame are basic Picea sitchensis.
I m wondering if changing frame into mahogany, and adding mohagony stripe will not add to much weight compared with original design.
if you are adding mahogany strip, I would not use epoxy wich will make a "breaking bond", I would use 3m 5200.
Regards,
Old 04-18-2007, 04:03 PM
Rep: 10 Posts: 24
Arcangeli
Hello Blackwatch,
Now the time was going on and I glued the first mahagony stripes after steaming them with PU Glue. This foam is working well with the wet fresh steamed wood. Epoxy was not possible. Later there will be screws in holes and small wooden plates over the screw.so it will be strong and all screws are hidden.
But what I īneed is a picture of the original Interieur in the baot. Seats, sides and so on .
On the picture are the first stripes
The original was 250 KG, and I will ad 40 KG max. So I think that is not the big difference, but the boat will be much stronger.
Good Luck with your restoration. If possible send me some pictures please
siegelofgermany@aol.com
Old 04-18-2007, 04:08 PM
Rep: 10 Posts: 24
sorry here is the picture
Old 04-20-2007, 05:15 AM
Rep: 10 Posts: 6
Sorry I have no good picture of the interior, My Arcangelli was also in very bad shape. There was no more floor.
Regards,
Old 04-20-2007, 02:14 PM
Rep: 10 Posts: 24
arcangelli
Thank you blackwatch, If I ve got the original seats and can put pictures in 10 days in this forum, some part also will be there then.
wish you much fun and I hope you ll never loose the power on a bad condition arcangeli projekt.
ATTENTION
Mine was totally new build in the hole bottom part, where the floor is .
attention to big stringers where bottom and the side plates are coming together.
These two were looking very good on my boat, but at all!!!!!! points where they where scruwed to the stringers wich cross the boat to the keel they were dryrottet and I had to change them, A boatbuilder gave me advice and I took the chance when the flanks where not installed and testet them buy bending them and they broke very easy at all points.!!!
Best regard
erhard
Old 05-18-2007, 03:58 AM
WoodenClassics WoodenClassics is offline
Arcangeli Jolly
I have restored an Arcangeli Super Jolly. Almost finished.
The best place to get full info on the Jolly is via the EWBC. Dirk de Munter has a Jolly fully restored. You can contact him via www.e-w-b-c.eu
You can also buy materials and parts for your restoration at www.woodenclassics.com/webshop.php
Dingco
Old 03-23-2008, 11:13 AM
Hanszz's Avatar
Hanszz Hanszz is offline
Arcangelifreak
Rep: 10 Posts: 59
See my Jolly at http://www.mijnalbum.nl/Album-CPGBUWJN-Foto's-in-'s-Gravenhage-Foto's-van-Vervoersmiddelen-Boot.html
As you see the restoration is not completed yet, more pic will follow.
http://www.e-w-b-c.eu/
thats the site of the European Wooden Boat Club
Hans
Old 03-23-2008, 04:12 PM
Rep: 10 Posts: 24
Arcangeli
Time was going on and the Arcangeli job was also going his way.
The bottom parts of the keel, and lot of other wood changed.
The plywood changed and on the plywood thin solid mahogany stripes glued and skrued.
Now the rest is a pleasure not a job
Arcangeli Jolly-bug-neu.jpg  Arcangeli Jolly-p3200043.jpg  Arcangeli Jolly-schrift-100-pixel.jpg
Old 03-24-2008, 05:49 AM
Hanszz's Avatar
Arcangelifreak
Rep: 10 Posts: 59
You are doin a good job Woodworm, I only did restore my deck. But what you do is a full restoration. Im new here at the forum, but I guess Ill stay here to watch you finish your job.
Old 03-24-2008, 11:18 AM
Hanszz's Avatar
Arcangelifreak
Rep: 10 Posts: 59
This is the original interior, for my Jolly 444
But what is original, when you look in the original books there you see a totally other interior.
Its just all custom made.
But I still do have the original 50HP to 60HP upgraded Mercury Kiekheafer OB
About the inside, I got the original inner sideplates, Im gonna make new panels and use the old ones
for the size and so. So if you would like, I could make some pics with the sizes in cm/inches.
Old 10-08-2008, 04:02 PM
Rep: 10 Posts: 24
not finished
the italien Girl is swimming, but nit finished.
The windowframe is selfmade, not orig.
Arcangeli Jolly-scheibe-innen.jpg  Arcangeli Jolly-deck-lack.jpg  Arcangeli Jolly-lack-lecken.jpg
Old 10-08-2008, 04:41 PM
Hanszz's Avatar
Arcangelifreak
Rep: 10 Posts: 59
Done a great job woodworm, looks really great!!!!
Old 01-21-2009, 08:07 AM
Rep: 10 Posts: 6
arcangeli Jolly n°222
Here seems to be the right place to show restaured arcangeli jolly
Still not at water, I do not have the time to take care of the motor, I hope it will be done in a couple of month. It is difficult to find parts for american motor... in europe.
Regards,
Arcangeli Jolly-vuegenraletribord.jpg  Arcangeli Jolly-vue-generalearriere.jpg  Arcangeli Jolly-img_3264.jpg
Old 01-21-2009, 03:31 PM
Hanszz's Avatar
Arcangelifreak
Rep: 10 Posts: 59
Look here for the results at my Jolly nr.444 from 1967
>> Restoring my Arcangeli Jolly <<
I will look for you for some sites (American) for motorparts, is it an Mercury??
If its a Mercury I got some good sites for you where you proberly will find the parts your looking for;
http://www.mercruiserparts.com/
http://outboardparts.com/
http://www.eastcoastmarineservice.co...accesories.htm
http://www.vintageoutboard.com/
http://www.mercguy.com/motors_for_sale.htm
especially the last link, mercguy is the site to be for parts of an old Merc.
I got an original 1966 Merc 50HP Kiehaefer and they got the stuff I needed.
The motor belongs to the boat, and its well alive now after I got the parts!!!!
