| Frosty, The local plumber who uses lead/tin solder uses it to "prepare the surface to be soldered... Diluted Hydrochloric acid, put empty crushed & cut up tinned cans to react with the tin part, when reaction (fizzing) stops use tongs to remove remaining metal, then try another piece of empty tinned can... Repeat last step till no further vigorous fizzing, then that liquid is KILLED SPIRIT of mur... acid ![]() ![]() ![]() ![]() |
| I bought muratic acid at a drugstore some years ago. I believe that masons use it to clean brickwork also. You may also try home improvement places, like Lowes, Home Depot etc. Pila |
| In Malaysia or Thailand? for Frosty??? |
| Hut Depot, perhaps? |
| Ille try the swimming pool supplies. Acid is an electrolite so the acid effect is not what is required as I see it. You are blasting it off by electric current flow taking chromium particles away. I would think therefore that battery acid would do the job. Even salt water?????? |
| i just sand blast my chrome,,,well,,,my usual "half" chrome stuff,,,but still gonne try the acid,,,,just cause hehehe ![]()
__________________ hehe ,,,,,Jim------> |
| Infusion RTM ? Tips & Tricks ? | Erwan | Fiberglass and Composite Boat Building | 2 | 07-09-2007 12:41 PM |
| Tips and tricks for perfecting your vacuum-bagging methods | duluthboats | Fiberglass and Composite Boat Building | 0 | 02-23-2007 03:25 PM |
| Cold Molding Details and Tricks | Thumper | Wooden Boat Building and Restoration | 7 | 01-19-2007 02:13 AM |
| Stripping Fiberglass | Chris Merriam | Wooden Boat Building and Restoration | 10 | 02-27-2005 03:11 PM |
| Stripping old paint | riggertroy | Wooden Boat Building and Restoration | 8 | 10-10-2004 05:01 PM |
