Old 08-07-2009, 10:44 AM
aka Terry Haines
Rep: 617 Posts: 1,475
Originally Posted by pitbull View Post
... I too want to strip plank a ply design (A Welsford Navigator) ... The reason I want to do this is because I like the look of the nagigator ...
-if you strip-plank a design intended for lapstrake it won't look the same.
... My plan would be to coat planks of plain sawn lumber with epoxy, let it dry and then cut it into battens. I would nail the battens to the frames using raptor plastic nails and perhaps glue it to the frames using Gorilla glue. The epoxy on 2-sides of the battens (top and bottom rather than inside and out) would ensure that these sides are coated effectively.
I would leave a small gap (1/16" or so) between the battens. Oce the hull is completely "planked" I would glass the inside of the hull and when that is hard, would force thickened expoxy between the battens from the outside and sand it all fair. Finally glass over outside of the hull.
-so you will have a strip-planked hull with extra-thick epoxy joints between the strips, glassed both sides. You have gone to a lot of trouble over those joints, it is not clear why. Compared to a quick squirt of regular glue on the joints which scrapes off easily afterwards, there is no saving of time or effort.
Dances with Turkeys
Old 08-07-2009, 02:19 PM
Guest20100203 Guest20100203 is offline
Rep: 0 Posts: 0
I know Terry, he's designed a batten seam method that will double the planking weight of the boat and a Navigator isn't a light boat to start with. He's also hinting at internal frames, suggesting he's making more structural burden.
DuFLEX strip plank mojounwin Materials 3 12-04-2007 05:34 AM
Strip-plank Chine Willallison Boatbuilding 6 10-26-2007 06:09 PM
Strip Plank Boat Plans Thomasw Powerboats 1 11-16-2006 08:42 PM
strip plank technique pingert Wooden Boat Building and Restoration 7 07-24-2004 01:58 PM
strip plank construction jimo Sailboats 2 05-26-2004 05:11 AM
