Old 09-03-2011, 10:59 AM
Paul Scott Paul Scott is offline
Rep: 84 Posts: 272
Adhesive and sealer compatibilities
If anyone knows,
What primer/sealer will stick to Titebond 3 / silicone bronze / Joubert 4mm Okoume? Urethane? (I know it's an epoxy centered universe, but I am allergic....)
( for a wee sailing canoe, who will be playing in the water, but sleeping in a heated garage.)
And as long as I'm on a roll, will the following stick?
Urethane on dried Liquid Nails?
Liquid nails on dried urethane?
Will the fumes from dried urethane melt extruded polystyrene?
P
Old 09-03-2011, 08:47 PM
tunnels tunnels is online now
old one !
Rep: 402 Posts: 1,918
Originally Posted by Paul Scott View Post
If anyone knows,
P
ask these guys http://www.glueguru.co.nz/
Making beautiful boats is a passion never a chore !
Old 09-03-2011, 08:53 PM
Rep: 3125 Posts: 9,403
Liquid Nails has absolutely no business on a boat, it's just not formulated to handle the environment or stresses. It is good for dry, static loads, but that's about it.
Old 09-03-2011, 09:23 PM
old one !
plus when it dries completely its hard and has no flex !!
Old 09-03-2011, 09:52 PM
Rep: 84 Posts: 272
LN holds extruded polystyrene together like nothing else I've tried. I'm looking for 2" longitudinal xps panels in light compression to keep flat vertical bow plywood skins from flexing in, not structural support. (take a look at Phil Stevo's IC blog to get the idea.) Do you think that longitudinal wood strips supported by wooden lateral triangulated cross bracing (like a Warren Truss) glued and screwed or nailed would be more effective than xps (as far as weight goes)given a non epoxy environment?
P
Old 09-04-2011, 02:24 PM
Rep: 84 Posts: 272
Thanks.
What goes on the wood first? Sealer/primer thudpucker Wooden Boat Building and Restoration 21 08-07-2011 04:40 PM
mould sealer? nevilleh Fiberglass and Composite Boat Building 5 10-15-2010 02:23 PM
Amerlock sealer Conachair Metal Boat Building 0 06-20-2009 07:13 AM
thompson's wood sealer...is that possible?! oceangboy2000 Wooden Boat Building and Restoration 5 01-06-2006 10:25 AM
Epoxy versus Cascamite & compatibilities Peter2004 Wooden Boat Building and Restoration 3 06-23-2004 07:00 AM
