Old 09-07-2008, 10:59 PM
Jakjit Singh Jakjit Singh is offline
Rep: 10 Posts: 13
Hai again,
I am now in the mist of building my Transom, I have done the rest of the frame, now left the transom only, can I use a 9mm ply and place a 1 1/2 " x 6 " of plank across the transom, for the outboard??
Old 09-08-2008, 12:45 AM
kengrome kengrome is offline
Rep: 287 Posts: 719
Yes you can, but I would recommend a clear 2x8 (1.5 x 7.5 inches) because it's taller and stronger. A 2x6 might be okay but the transom is really not the place to skimp on strength since the entire weight of the boat is being pushed from there.
Kenneth Grome
Old 09-08-2008, 04:06 AM
Rep: 10 Posts: 13
Thanks angain Ken..
Old 09-08-2008, 04:07 AM
Rep: 10 Posts: 13
Sorry... should read as "Thanks again Ken"
Old 09-11-2008, 12:14 AM
Rep: 10 Posts: 13
I intend to fiberglass my wooden plywood fishing boat, but before I fiberglass(encaplulating) it what should I do ... Pls advise... Thanks
Old 09-11-2008, 01:31 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1059 Posts: 2,194
make sure all holes and voids are filled. make sure all turns (angles) are sanded to a radius of not less than 1/2 inch.
Follow the surface preparation guides you will find all over the internet that recomend things like a complete clean with acetone, then plain water.
Make sure the surface is fully dry and dust free, and then give it an initial coat or two of epoxy.
Really, there are about three million detailed explanations of applying epoxy on the internet, lots of advice on previous discussions - you dont need to be told in detail all over again in this thread.
Old 09-11-2008, 03:49 AM
northerncat northerncat is offline
Rep: 9 Posts: 170
Originally Posted by lazeyjack View Post
so funny Paul\, I saw a 39 foot cat here, built of 10mm ply, and the silly bugger was going offshore, this bloke spent 30 mins telling me how light the thing was
I have a theory, if you can put a sledge through a boats side then it should never venture offshore
thats actually really funny cause i know of a lot of 40ft cats that go offshore that are all built from 9mm ply and a lot of them are still sailing
sean
Old 10-05-2008, 11:23 PM
Rep: 10 Posts: 13
Hi.. How high normally the side of a boat to build, say in my case my boat is an open fishing boat and its 24 feet long and about 5 to 6 feet wide?? advice please???
Old 10-06-2008, 12:11 AM
boat fan's Avatar
boat fan boat fan is offline
Rep: 357 Posts: 679
FOLLOW THE PLANS PLEASE !!!! I Assume you have them ?
  #25
Old 10-06-2008, 01:43 AM
Rep: 10 Posts: 13
Actually I modified the width. The original width is 4 feet, so do I need to increase the height of the side frame (by how much), I am thinking a 3 feet high...
  #26
Old 10-06-2008, 02:11 AM
Rep: 287 Posts: 719
Wider or narrower? By how much? What is the new width? If it is wider it's going to give you a faster roll -- hopefully not so much that it will injure the passengers or make them seasick.
Is it too late to go back and build it according to plans?
If you don't want to make the sides the proper height according to the plans, you can make them taller for better seakeeping, or you can make them shorter so nets and crab/lobster/fish traps are easier to use.
Kenneth Grome
  #27
Old 10-06-2008, 03:58 AM
Rep: 10 Posts: 13
Its wider by 1 1/2 feet... I has finish building the frames and now on the building jig. Too late ot go back.
  #28
Old 10-06-2008, 04:06 AM
Rep: 287 Posts: 719
Well then, good luck. I hope it performs acceptably with such an extreme modification.
Kenneth Grome
  #29
Old 10-05-2009, 04:07 AM
scott_in_az scott_in_az is offline
Flotsam
Rep: 10 Posts: 15
Hi All,
Thought I would bump up this thread as I would love to hear of any progress Jakjit or others have made on builds based on the FAO V-Bottom Fishing boat plans. I recently downloaded the plans and was pleased to see much of the process well detailed.
Jakjit mentioned building the boat at 24 ft x 5ft (adding that he was widening the beam from 4 ft.) The plans for this boat (in each of the several lengths detailed) is, I belive actually 6 ft.
Surprisingly, the process for widening the beam of this design (up to a max of 20%) is also well detailed in the plans. It does not call for increasing the height of the side frames. The plans detail both traditional planking and plywood construction (9mm).
I was attracted to the boat by the designers stated design goals and the combination of sweeping sheeer and V-bottomed entry. The amount of rocker, and the narrowing of the beam towards the light weight transom (9mm) reflect the low power (6-8 hp), low speed (6-8 knots) intentions of the designer (Oyvind Gulbrandson). Though I might prefer a design with a little less rocker, a little wider aft, and a transom stressed for 20-30 hp, I am hoping to find photos or other input from builders of the FOA boats currently under construction.
Hats off to the designer, and to the United Nations FAO for making the plans freely available.
Scott
  #30
Old 10-05-2009, 08:00 PM
Flotsam
Rep: 10 Posts: 15
whoops
one side plywood, one side fiberglass/epoxy, polystyrene core? murv Materials 4 05-18-2007 08:06 PM
Newby question regarding Epoxy and fiberglass redecking and plywood choices baranx4 Boatbuilding 3 03-05-2007 08:55 AM
fiberglass on plywood Jan Van Boat Design 6 07-25-2006 04:30 PM
that is the diference between plywood and fiberglass? tamkvaitis Boatbuilding 9 12-27-2005 07:11 PM
Planks to plywood or fiberglass ajoan Wooden Boat Building and Restoration 2 10-25-2005 05:09 PM
