| 8' El Toro Damage Hi There: my first time doing this ~ thanks for your patience. The pixture shows dry rot damage to the bowplate and extends about 1" down the side of the pram. Is a small area but one I want to repair. This is the only structural damage. I also need help with suggestions to strip and repaint per my previous post. The pram is of plywood construction. Oh, the numbers 5361 are etched, branded or??? into the centerpiece of wood(don't know the term) in the interior. Hull ### ????? Thanks for the help, Steve |
| no picture////................. |
| Sorry rasorinc, i'm working on it. thanks for your patience |
| hope this goes through now |
| again ~ ![]() |
| nope no pic. |
| hi rasorinc ~ thanks for stayin with me. steve |
| OrcaBait, to include an image click on Go Advanced, scroll down to find Manage Attachments and click on that. With that you can search and open your own folders, select and upload an image file. It will handle most types, but as a courtesy to people with slow connections I suggest you convert bmp files to jpg so it loads quicker. When this is done the application will tell you the size of the file it has uploaded. At that point you can close the Manage Attachments box, add your text and post. Your image will appear as a Thumbnail that people can click on. Also, you can do this retroactively if you forget, by clicking on Edit at the bottom right of your post. It is probably better if you keep your posts in a single thread while you are on the same topic rather than starting a new thread.
| 8' El Toro Sailing Pram Renovation | orca bait | Wooden Boat Building and Restoration | 2 | 02-17-2009 04:55 PM |
| Damage | seaandland | Sailboats | 1 | 01-24-2007 02:26 PM |
| Damage | seaandland | Boat Design | 1 | 01-24-2007 01:48 PM |
| damage | seaandland | Fiberglass and Composite Boat Building | 1 | 01-24-2007 01:47 PM |
| Hull Damage - can fix? | qbert | Open Discussion: All Things Boats & Boating | 18 | 03-27-2006 05:08 PM |
