Old 06-15-2011, 11:21 AM
bswindell bswindell is offline
Rep: 10 Posts: 2
73' Paddle Wheel Boat
Am restoring old paddle wheel double-deck boat. Basically it's a wooden structure on top of a solid piece of styrofoam with 17 wraps of fiberglass. There is 2' hangover of 2x4 crossbeams and treated 3/4" plywood. Any suggestions on the best way to fill gaps & waterproof the wooden underside? The lower deck will also need to be sealed somehow.
Old 06-15-2011, 05:49 PM
Rep: 3125 Posts: 9,403
Without pictures and a much more intensive description of what you're trying to do, not much help can be offered. Sealing wood is a fairly straight forward process. Epoxy is the usual choice and the methods and products are well covered here and elsewhere in the net. Don't let anyone attempt to tell you that polyester will work, it doesn't and the debate is only left to those that can't believe, the long term testing results available.
A 73' vessel is substantial enough to warrant a full survey and inspection. It's also a project large enough to require a crew to repair. You can make a career hacking away at it a little at a time, or hire a crew that can bang it out in a few weeks. Considering the very generic nature of your questions, you'd be best advised to have the vessel surveyed right away, then you can begin the education process, about the materials and techniques necessary, to get this puppy back in service.
Old 06-15-2011, 06:33 PM
Rep: 10 Posts: 2
73' Paddle Wheel
I will try to post a picture sometime tomorrow. This project has already been going on for a couple of months. Most of the wood replacement is complete & now it's time to get down to the sealing, painting, finish work. Besides the four of us that own the boat, there are 2 carpenters that have done most of the major work. Appreciate your input & I hope the pictures that I post later will help.
Old 06-15-2011, 10:13 PM
The wood should have been encapsulated before it went in the boat. What kind of carpenters have you working on the job?
Old 06-16-2011, 05:52 PM
Corley Corley is online now
epoxy coated
Rep: 524 Posts: 632
It's a strange form of construction if I recall correctly styrofoam is not a closed cell foam and will eventually become waterlogged if moisture enters the core.
I suppose if it's wrapped 17 times with fibreglass cloth and an appropriate epoxy resin it's likely to be ok certainly would not be my choice if I was building a boat of this scale though.
I assume this boat is for personal use? Sounds like it would be a nightmare to get through any form of survey for commercial usage.
Old 06-16-2011, 06:17 PM
Rep: 1493 Posts: 7,447
Lots of floating docks are built over styrofoam blocks. The main problem is rats nesting in them.
pedal driven paddle wheel boat? creekhound Boat Design 37 06-18-2010 08:16 PM
Modern Paddle Wheel/Amphibious Craft. localman Boat Design 24 04-27-2010 10:44 AM
Do they exist? articulating paddle wheel justinDesign Propulsion 27 02-01-2009 08:31 PM
Paddle wheel question dick stave Boat Design 6 10-18-2008 11:22 AM
Anyone have articulation paddle wheel info justinDesign Boat Design 19 10-04-2007 10:52 AM
