| '58 Thompson 16 lapstrake... It's MINE...(for $200) |
| Nice. Want to make $200? |
| Add a zero...OK! otherwise...I think I'll play with it myself ![]() |
| The rest of the pictures (I think) for now. Will get more soon |
| I've repaired and restored about a dozen of those. You haven't gotten the deal you think you have. Place 200 pounds near the transom and launch her and you'll quickly see. It's still a good find, in fairly good condition, but I see "stuff" in a few of your photos. It would be very wise to get her sitting on her keel as quickly as possible, with very little weight on the bunks. |
| She looks like a very worthwhile fixerupper, though. |
| Yup...saw the "stuff"...I expect to see more when I get the paint off the bottom and check out the keel area. I got a little leaking along the keel when I lifted the tongue of the trailer it was on and the inch or so of collected water ran aft...it kind of dribbled on itself and the rest leaked out the bottom end... Yeow! Sounds like a description of me 30 years from now! The floor boards look to be in good shape though...lots of peeling varnish (I don't think they sanded when they re-varnished) but the stuff next to the wood is surprisingly intact. Plenty of dust and dirt down in there makes it look cruddy. I stuck an awl anywhere I thought the fungi might find tasty and found all solid wood...but like I say, could be rot city under the outside gazillion layers of paint. Quote:
Thanks for the heads up on the trailer...I hadn't noticed it. I shoved a wedge under the keel so now it only teeters onto the bunks and I can pivot them easily...maybe only a few lbs on them. Got any thoughts on getting the bungs out without destroying the screws underneath? |
| He meant that it is going to leak. You'll want it evenly supported on its keel. The bungs are just put in with varnish, they'll spin right out with an undersized bit. Every once in a while, some genius puts 'em in with epoxy to "do it right" but DO hope not. Don't worry about the fastener so much as the surrounding wood. Don't F it up. |
| When I want to drill without messing up surrounding area, such as in your case, I pre-drill a scrap and position the drilled scrap over the target and clamp it securely before attacking it with the drill bit, avoiding it dancing off into the protected area. |
| Bungs are easy to remove if installed properly. Use a course thread drywall screw and slowly drive it into the center of the bung. When it bottoms out against the fastener below, it will force the bung up, often intact. If it does break, you can pick out the bung pieces easily enough. Go slow or you can break the drywall screw or bugger the fastener slot below. You're going to love redoing those laps Steve. Take your time and find a happy place when you get pissed (which you will). |
| I forgot the drywall bit. That's better. |
| Decking screws work like drywall screws, but are stronger and harder to break. |
| You only need one Hoytedow to do a whole boat. Okay, maybe you break one and you need two for a whole boat. |
| Any pics of a circa 1969 center console Bertram (pic of mine inside) | Valkyrie | Powerboats | 13 | 08-16-2007 07:46 AM |
| repainting Thompson, below waterline | bigfootnampa | Wooden Boat Building and Restoration | 3 | 07-06-2005 10:53 PM |
| New deck for a 1958 14' Thompson Runabout. | Sultana | Wooden Boat Building and Restoration | 3 | 05-01-2005 10:25 PM |
| What is this boat of mine? | korpi | Powerboats | 13 | 02-11-2005 04:00 AM |
| Thompson Marine Auction | duluthboats | Marketplace | 4 | 10-04-2002 03:25 PM |
