Old 09-10-2006, 08:21 PM
Hunter25 Hunter25 is offline
Rep: 46 Posts: 173
If the seams get too big they need to be repaired, which usually involves cutting out sections along the edge of the plank and machining a replacement edge, which gets glued in. Then the boat is caulked properly. Sikaflex 291 will work fine, but use the recommendations of your corker, he will have a favorite, probably with many reasons to back it up. Again, There are other methods to repair this construction type, but it takes a skilled person to machine the seams, if going that route.
developing new 36' C/R, market research ... lucas adriaanse Sailboats 22 08-10-2010 06:42 AM
Floating Nightclub, Barge? Pontoons? or magic? Swashbuckler Boat Design 4 08-30-2004 10:50 AM
Angleman Ketch 36' mevysen Wooden Boat Building and Restoration 1 03-12-2004 08:39 PM
location of centerline on 36' sailboat Guest Boatbuilding 2 08-14-2003 11:46 AM
Orca 36' Nomad Powerboats 0 07-19-2002 09:48 PM
