Old 04-01-2010, 09:43 PM
robertgrandbois robertgrandbois is offline
Rep: 10 Posts: 14
3/8 or 1/2 inch ply?
I am restoring an old plywood boat. The frame is all red oak and in very decent shape. There was 3/8 plywood on it before, but I can get 1/2 inch on sale at half price but I am scared it will not bend at the bow. Can I do the bow with two layers of 1/4 and the rest with 1/2 inch?
3/8 or 1/2 inch ply?-boat-restoration-project-101-030.jpg
Old 04-01-2010, 11:11 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
You're right to be worried. The thicker plywood isn't just 50% stiffer. It's probably about twice as stiff as the 3/8. Unfortunately, short of running the finished piece through a drum sander to make it thinner, you'll have to bite the bullet and buy the more expensive plywood.
You could, as you mentioned, use two layers of 1/4" plywood, but you will use a lot of epoxy becuae the whole piece ought to be 1/4", or else you'll have to scarf it in, which is a lot of bother, to say the least.
Old 04-02-2010, 07:36 AM
Rep: 10 Posts: 14
that is what i tought but was hoping to save a few bucks. i will go with the 3/8 plywood. Now could i use the 1/2 inch for the top? it does not seem to have much curves to it.
Old 04-02-2010, 08:41 AM
alan white's Avatar
Yes, of course, at the cost of some extra weight.
Old 04-02-2010, 08:47 AM
tom28571 tom28571 is offline
Rep: 1500 Posts: 1,681
You can scarf a piece of 3/8 to the 1/2 for the bow section. Works fine and this method is used by many.
Tom Lathrop
Old 04-02-2010, 07:01 PM
Rep: 10 Posts: 14
ok tom i but i was thinking of doing a but joint would that work?
Old 04-03-2010, 08:57 AM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,842
no...the transition needs to be as strong as possible. To use a butt block you need to have the same thickness to butt together. That option really needs a 12:1 scarf.
Old 04-03-2010, 09:43 AM
alan white's Avatar
That's true. It would work fine and would be practical if a scarf was required anyway to lengthen the panel. If not, buy the 3/8" plywood and save the hassle.
Old 04-04-2010, 07:43 PM
Rep: 10 Posts: 14
I got the ok to get all 3/8 from upper management(wife). There originally was a scarf but I was thinking of a butt joint instead be faster.
Old 04-04-2010, 08:07 PM
alan white's Avatar
A butt located where there's not much curve or twist, with a backing plate, is not a problem. Especially if the exterior will be glassed.
Old 04-04-2010, 10:18 PM
aka Terry Haines
Rep: 1814 Posts: 3,009
Material stiffness varies as the cube of thickness. 4/8 thick ply compared to 3/8 ply would be stiffer by a factor of (4/3)^3 = 2.37
Thats assuming uniform material. However if the ply has relatively few, thick veneers, it would be more flexible in one direction, so perhaps you could use it "cross-grained" and still get around the bends.
Dances with Turkeys
4 inch pvc pipe raft. rickjames Boat Design 17 07-13-2009 11:40 AM
1/4 inch Plywood canopy roof Bill57 Wooden Boat Building and Restoration 3 05-17-2009 08:14 AM
Monel 1/4 inch narrow crown staples missinginaction Wooden Boat Building and Restoration 1 09-11-2008 11:51 AM
Magmotor S28-400 with 8 inch prop direct drive. klick Hybrid 47 08-05-2008 08:14 PM
absolute beginner ply/epoxy or ply/glass wannabe Materials 9 08-13-2004 05:01 AM
