Old 07-05-2006, 11:50 PM
zero zero is offline
Rep: 10 Posts: 6
26' clinker lifeboat
im looking for any info on a 26' clinker lifeboat i recentely bought. its all teak with 2 masts and a bowsprit. im trying to find out what kind of rig it carries(i believe aketch rig) and some possibilities for a restoration/conversion. anyone?
Old 07-06-2006, 05:45 AM
Sander Rave's Avatar
Sander Rave Sander Rave is offline
Rep: 59 Posts: 201
Dear Zero,
Depends.. the original lifeboats I know carry different kind of rigs, starting with a bucket sail and jib. Do you know if it's an original rig, or is it modificated for sailing?
In Holland there was a time to convert a lifeboat to a sailboat. That was somewhere around the 1930's to 50's I believe. The original bucket rig was mostly converted to a ketch rig. We still have a lot of them sailing around.
In fact, I think my next project will be identical to yours... I'm waiting till summer is gone though, having too much fun on the water right now.
I can find a publication on a dutch lifeboat builder with original photo's if you like. But these are build from oak and the rig is a bucket rig only to get ashore.
Regards
Sander Rave
SkottKarra industrieel ontwerpers
skottkarra.com
Old 07-06-2006, 09:55 AM
Rep: 10 Posts: 6
bucket rig?
im not familiar with a bucket rig, although i do believe what it has is not original. from my research i havent found aanything that carried a bowsprit originally. it was built in 1917 (that from the man i bought it from) and it is fitted to hold an inboard, again i dont know if that is original either. and thanks for the reply.
Old 07-06-2006, 10:58 AM
Rep: 59 Posts: 201
Dear Zero,
I looked up some pictures of different lifeboats for sale at the moment in Holland for your information. Just look in my galery. I hope it'll point you in the right direction.
Good luck!
Sander Rave
skottkarra.com
Old 07-07-2006, 12:41 AM
Rep: 10 Posts: 6
much appreciated photos! i can see my boat has a lot of potential, those photos are inspiring. now my problem is how far do i want to take this "little" project. i was thinking i might leave it partially open(right now it is totally open-down to frames and floors). first things first, replacing a couple floor timbers and frames. also im wondering about adding a bit of deadwood/keel. right now there is only a couple inches of keel. maybe to some ideas about balasting her, ive heard sand bagging isnt a bad option.?
Old 07-07-2006, 03:41 AM
Rep: 59 Posts: 201
I know all different kind of keels are being used, sandbagging is at least the most easy one. The life boat we use for rowing used to have a steel longkeel along the keel line and I've even seen sailing life boats with bilge keel.
Sander Rave
skottkarra.com
Old 07-07-2006, 06:32 AM
Mikefleetwood Mikefleetwood is offline
Rep: 10 Posts: 12
Perhaps you should look at "Cornish Pilot Gigs" - try any search engine.
They are about 30' clinker built pulling (rowing) boats for sea use, design dating back 200 years. The forerunners of the purpose built lifeboats. Some were rigged for sailing. Traditional rig is ketch with large dipping-lugg for main and small mizzen (mostly for stability). No keels or ballast, relying on crew shifting to keep her the right way up!
Old 07-08-2006, 02:04 AM
Rep: 10 Posts: 6
clinker conversion
im trying to attach some photos, but am having problems. i was just told about a couple of books that deal with boat conversions and more to the point , has specific details of lifeboat conversions. one is "practical conversions and yacht repair" by michael verney and the other is "small boat conversions" by john lewis. i havent looked at either but ill report back after ive seen them. also ive got some other feedback that lifeboats arent good sailer in general and something about the sheer being too extreme for a cabin. i personally love the lines of the sheer on these boats but i want to also know any glitches i might run into. ill try to get those photos of my boat soon. thanks
Old 07-09-2006, 10:10 AM
Rep: 10 Posts: 6
photos lifeboat
here are the only photos i have of my boat. in another forum im hearing mostly negative responses about the sailing qualities of lifeboats. i agree a keel and ballast(perhaps alot) will be needed to allow her to track better and sail to windward. im curious about the photos i view from sanders. what is different below the waterline on those vessels. they look like they are clipping right along in those pix.www.picturetrail.com/zroland1
Old 07-10-2006, 04:52 AM
Rep: 59 Posts: 201
Funny,
Together with my (lifeboat) rowing team we plan to bring our boat under sail again, and she has more or less the same lines as yours. It has been under sail 10 or so years ago. As I can recall we had a steel long keel attached to the keel line. It was 30-50cm deep, some 3 meters long. Yours seems to be very authentic though.
For the sailing qualities, I guess it's not the fastest sailer. Who cares, as long as it's fun sailing with up to 10 people in relative comfy conditions. there are little sail boats that size that can handle that amount of people and still have fun.
Sander Rave
skottkarra.com
Old 07-21-2006, 01:52 AM
Rep: 10 Posts: 6
good book
i just got a book called "small boat conversion" by john lewis. it has all the plans, including the original lines drawings before and after conversion, sail plan for a ketch rig. the boat he converts has the same numbers as mine,exactly what i need to get started. anyone doing a lifeboat conversion sould check it out.
Old 07-21-2006, 05:56 AM
Rep: 59 Posts: 201
Thanks for the info and good luck to you!
Sander Rave
skottkarra.com
Clinker plank replacement Andy Wooden Boat Building and Restoration 5 01-08-2006 08:47 AM
Refastening clinker hull Andy Wooden Boat Building and Restoration 3 03-29-2005 10:36 PM
Clinker Hull Design edward Boat Design 2 03-25-2005 11:06 PM
14ft Clinker Plywood Runabout Matt74 Wooden Boat Building and Restoration 1 11-07-2004 09:59 PM
Outboard for a SeaCraft Kauri Clinker RipTorn Wooden Boat Building and Restoration 0 01-29-2004 05:11 AM
