22' Longboat re-fit (Cont.)
Discussion in 'Wooden Boat Building and Restoration' started by Pengreg01, May 13, 2016.
  1. Pengreg01
    Pengreg01 Junior Member
    moved from fibreglass boat building
    It WORKED!
    Approx 70 x 35mm section took the curve beautifully. I suspect that the black plastic had a lot to do with it. The steam rig was only able to heat around 1m at a time so I moved around the bend. Also it heats in the direction you aim the pipe (Duh)
