Old 02-14-2010, 10:21 AM
Rowcat Rowcat is offline
Rep: 10 Posts: 3
21 ft flat bottom 2 man Row boat.. Sliding seats
I just completed a 21 ft 2 man rowing boat. I gave up speed for stability by using a flat bottom, although I am still getting around 4 knots with one man. Nice high sides that can take rough water. Please see pictures of the wood outrigger system. No need to purchase a row-wing drop in sliding seat and outriggers when you can make your own. Even the oars are long 2x4's with plywood faces. as soon as I figure out how to downsize my photos so that I can upload them I will...By the way, ripped down 2x4's to make them narrower and them put a groove down the middle to accomodate roller blade wheels. The padded seats I made each have 4 roller blade wheels, 2 per side that roll the seat up and down the rails. On a long row, it is your legs that are worn out, not your upper body. Kind of like sculling, but you can bring your girl and some beer. Plenty of room for everything, plus stable . I can stand up to pee. Try that in a rowing shell.
Old 02-14-2010, 12:03 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
Hi Rowcat,
Exactly what kind of activity is it you have in mind abord this thing ? I see the girl, slide seats, beer, warn legs, plenty of room. I haven't tried sculling with a chick in years and you're right, I won't try it in a rowing shell
It does sound good though.
Regards
Fanie
Water ! Just gimme water !
Old 02-14-2010, 12:30 PM
Rep: 10 Posts: 3
21 rower
I would say the boat is a "jack of all trades, master of none" but for me, it is the master of the water way. Perhaps a pulling wherry. Nice and wide at the midships, somewhat canoe like at the ends. A lean mean green rowing machine.
Old 02-14-2010, 01:37 PM
Fanie's Avatar
Fanie
The best boat there is is the one you enjoy the most. It will make others with much bigger or nicer boats envy yours
Enjoy every moment of it.
Regards
Fanie
Old 02-15-2010, 03:43 AM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,842
Sounds kinda like a Guide boat...kind of a rowing canoe, quite large, to carry lots of customers or plenty of gear for a few customers.
Old 02-15-2010, 05:35 AM
Rep: 10 Posts: 3
outriggers
One thing I would like to point out is the wooden outriggers. a 1x4 parallel to the sides of the boat allow the oars to rest upon the 1x4 and all the other wood serves to support this 1x4 or serves as a pivot point for the oars force as you pull them. Outriggers that far out from the boat allows much longer oars and with the sliding seat, maximum effeciency, at least for a flat bottom boat.
Help building a 17' long x 50" bottom flat bottom aluminum boat Loewman Boat Design 22 11-21-2011 12:31 PM
Flat bottom/vertical sides/flat deck/ flat everything Ron Cook Sailboats 74 08-12-2009 08:51 AM
Flat Bottom Sail/Row Boat DiningShip Boat Design 2 03-23-2009 12:38 PM
Need a design for a flat bottom boat AliBaba Boat Design 4 04-29-2005 06:40 AM
Flat Bottom Boat Marsh Man Open Discussion: All Things Boats & Boating 9 05-18-2004 03:01 PM
