Old 07-18-2005, 02:07 PM
Ralphw Ralphw is offline
Rep: 10 Posts: 4
1960 Grady White Transom
Long time reader/first time poster.
My question is....I am replacing the transom on my 18 foot grady white.
original transom is 2 layers of solid mohagony...outer layer is horizontal inside vertical, on the original they where not glued together and the inside vertical boards where just screwed in tight together not even edge glued.
Would it hurt anything to sandwich epoxy between these 2 layers of solid mohogany?
also should I edge glue the inside boards for more stiffness?
Thank you very much,
Ralphw
BTW awesome site.
Old 07-20-2005, 12:32 AM
Rep: 1397 Posts: 7,216
A rigid structure attached to a flexible one will most likely be a problem. The original design lasted for a long time.
Old 07-20-2005, 02:45 AM
Rep: 2891 Posts: 8,798
Gonzo is correct, don't glue the planks. The outer planks will move and the inner planks will try to prevent this, something's going to give. Replace the fasteners to firm up the transom (cheapest), rebuild the transom (next to the cheapest) or re-engineer the transom (not so cheap) as a composite that looks like the original, but has a plywood core.
Transom Bracket on a 19ft boat CapeCodder Powerboats 6 12-07-2011 10:30 AM
best low tox wood preservative lofting4fun Wooden Boat Building and Restoration 3 08-27-2005 03:33 PM
Grady White Boston Whaler vs. SeaSwirl / Proline blee Powerboats 3 03-25-2005 10:13 PM
Attaching stringers to transom? mikkyle Fiberglass and Composite Boat Building 3 12-13-2004 03:21 AM
Composite Question, filling transom holes foca Powerboats 5 07-10-2004 12:46 AM
