Old 05-16-2009, 10:02 PM
Bill57 Bill57 is offline
1/4 inch Plywood canopy roof
I'm building a wooden canopy for a 23 ft steam launch. The basic shape of the canopy is an ellipse about 15.5 feet by 6 feet. There is a slight curve from left to right and front to back, sort of like a potato chip. The frame has a perimeter about 2.5 inches tall and made of 3 strips of 1/4 marine fir plywood epoxied together with 7 radiata pine cross pieces every 2 feet.
I'll be using 1/4 inch plywood for the skin of the roof, but I'm not sure what type of plywood wood be best. I intitially thought of using luan with the top covered with epoxy/6oz cloth and then paint. But now I'm wondering if a better plywood ( okume ? ) and Interlux Brightsides paint on top would be easier and just as good. There will be a few seams where sheets meet that might need a strip of cloth and epoxy.
Any opinions or advice would be greatly appreciated.
Bill
Old 05-16-2009, 11:51 PM
Rep: 2891 Posts: 8,792
Pictures will determine, if the compound curves you've described can be accommodated with plywood. You can force thin plywood to take some compound, but not a lot.
If this is the case you'll have to diagonally plank the top. I'd recommend two layers of 1/8" might be a better choice so you can stagger the joints and have the strength necessary.
Home improvement luan is usually very poorly made, has very thin external veneers and only 3 layers. There's also the potential for less then waterproof glues used within the panel.
Depending on where you live in Maryland (I grew up on the eastern shore) you should be able to find a marine plywood retailer fairly easily.
Sheathing with 6 ounce and epoxy is just a good idea and will preserve what you got.
If the compound curve isn't too severe, then you can usually force the plywood to take this shape, though it will place a fairly high stress on the frame work holding up the canopy. More often then not when you force a piece of plywood like this you need closer beam spacing then you have, but if the curves aren't that bad, it could work.
Again, these are just guesses until we can get a look at what you're dealing with.
Old 05-16-2009, 11:57 PM
alan white's Avatar
Rep: 1168 Posts: 3,269
You'd be best advised to use a marine plywood for lack of voids and thick enough surface plies, along with overall uniformity. However, your roof is also very well suited to cedar (or similar light wood) strip construction, which will yield a slightly thicker but likely about equal weight structure. It weould have to be glassed both top and bottom but you'll save on plywood costs and there won't be any seam issues. It would be stiffer as well.
Old 05-17-2009, 09:14 AM
Capt. Mike Capt. Mike is offline
Rep: 30 Posts: 24
Consider making the frame as you described, but then use a fabric (Sunbrella) cover. You can get the curves you want by using supports with the curves you want.
Monel 1/4 inch narrow crown staples missinginaction Wooden Boat Building and Restoration 1 09-11-2008 12:51 PM
Magmotor S28-400 with 8 inch prop direct drive. klick Hybrid 47 08-05-2008 09:14 PM
F-16 Canopy PetterM Powerboats 1 11-28-2007 09:34 PM
f-16 canopy... where to buy? Guest Materials 2 01-06-2005 10:47 PM
Plastic Canopy Archive Powerboats 1 06-12-2001 03:47 AM
