Go Back   Boat Design Forums > Design > Propulsion > Surface Drives
Old 10-19-2008, 06:11 PM
srimes srimes is offline
Rep: 186 Posts: 226
Transmission-free surface drive? (jet pump reverse bucket)
Please excuse me for posting while intoxicated.
Would a reversing bucket like that used on jet pumps work on a surface drive? A bucket isn't really feasible on regular inboards cause it needs to be out of the water when going forward, but this wouldn't be a prob on a surface drive. I like to potential simplicity of surface drives and if you could do without a transmission that'd be that much cooler.
For a fixed shaft w/ rudder the bucket would have to turn much like a kitchen rudder. Heck, a kitchen rudder would probably work fine for low speeds but at higher speeds would cause too much drag.
What do yall think?
Old 10-20-2008, 03:48 AM
CDK's Avatar
CDK CDK is offline
experimental engineer
Rep: 1316 Posts: 2,145
Now that your head has cleared you probably already have doubts about the idea. Even on a jet the reverse bucket is a doubtful construction, but at least there is no rudder in the way there.
Old 10-20-2008, 08:51 AM
Rep: 472 Posts: 1,391
Engineering while intoxicated is against the law isn't it... EUI
Old 10-20-2008, 04:00 PM
PetterM's Avatar
PetterM PetterM is offline
Rep: 197 Posts: 164
What do yall think?
There is no reason what this should not work, in fact I think Renato Sony Levi tested a similar arrangment at some point....I think it was quite difficult to control though...
www.berserkdesign.com
Old 10-27-2008, 07:38 PM
Rep: 186 Posts: 226
cool, thanks. Jets do well backing up w/ their reverse bucket, right?
Do you know if Mr. Levi used a sloped transom when trying the reverse bucket? I've read that reverse isn't so hot on surface drives w/ rudders unless the transom is angled.
Old 10-28-2008, 04:43 AM
PetterM's Avatar
Rep: 197 Posts: 164
I am not sure. It was described in his book “milestones in my design” I think, will try to check at home tonight.
Old 10-30-2008, 04:57 AM
PetterM's Avatar
Rep: 197 Posts: 164
A had a look last night, there was no illustrations but I would guess its similar to the LDU?
If you are planning to design your own surface drive, then I would recommend that you buy Levi’s book “Milstones of my Designs”.
Old 10-30-2008, 11:21 AM
StianM's Avatar
StianM StianM is offline
Rep: 114 Posts: 577
Won't work
A jet sucks the water from below the boat so the jet pointed backwards make posetive trust and if you direct it forward it will create negative trust.
A surface drive sucks the water from the front of the boat so directiing the trust forward will only work against the work done to push the water backwards and you will just not get annywhere.
Old 10-30-2008, 08:10 PM
Rep: 186 Posts: 226
blowing totally beats sucking for creating thrust. As far as thrust is concerned, sucking sucks. find an explination of "pop pop boats" for a better idea.
Old 11-02-2008, 12:10 AM
MattZ MattZ is offline
Rep: 21 Posts: 65
Originally Posted by StianM View Post
Won't work
Actually, if the reverse buckets reduce the flow into a smaller area it will work. There's a device called a Kitchen Rudder, invented by Admiral Jack Kitchen of the British Royal Navy that does exactly that.
Also, the thrust reversers used by commercial jets draw air in the front yet provide negative thrust by pointing the thrust forward.
Old 11-02-2008, 10:28 AM
StianM's Avatar
Rep: 114 Posts: 577
At speed the engine is feeded with air and therfor the negative trust only work against the moving force of the airplane. Atleast I gues so since I allways see the aircrafts pushed into the airport by viecles and don't use there own thrust to get out.
Just thinking out loud (no facts presented in this post)
Old 11-02-2008, 11:45 AM
Rep: 21 Posts: 65
Commercial jets can back up from a standstill with the thrust reversers. Boats with a Kitchen Rudder can back up from a standstill. Here's a link to a pulsejet powered go kart that draws air in from the rear, forces it out the rear, and still develops a forward thrust: http://www.youtube.com/watch?v=5U-grFuXZ9U
Stricly speaking, it's not the 'suction' or the 'discharge' that drives you forward. It's the transfer of momentum to the fluid, whatever it may be (air, water, rocket fuel.)
Here's a simple calculation to make my point: (I'm Canadian so I'm doing this in metric.) Lets say you have a jet pump sucking in 100L/s of water. It 'sucks' water in the front and 'pushes' it out the front. So the suction would 'pull' the boat forward, but the discharge would push is back, and we shouldn't go anywhere. But there's a little bit more to it. It depends how fast you're sucking, and how fast you're discharging. If the nozzle converges then the discharge velocity is much higher so there's more momentum in the water being discharged than in the water being drawn in.
Old 11-02-2008, 03:42 PM
StianM's Avatar
Rep: 114 Posts: 577
There is a god after all
Old 11-02-2008, 05:05 PM
Rep: 21 Posts: 65
Sorry, I did a quick calculation, but never posted the numbers. Basically it comes from Reynold's Transport Theorem if you've ever studied fluid mechanics. It's a first order approximation in most cases, but it proves the general existence of the phenomenon.
Old 04-02-2009, 12:05 PM
Mark Emaus Mark Emaus is offline
Rep: 20 Posts: 86
Not true,
Jets do not use reverse thrust to back up anymore because the engines are to low to the surface and thus pick up FOD creating damage to the blades. Jets like the B727 and MD80 can use reverse thrust to back up and they work very well. I did an expermiment with a long tail mudmotor by building a bucket to provide reverse and it worked. We are now looking at making a similar type bucket used by jet skis for a mud motor reverse. I must note that the reverse is only going to be used for docking and slow speeds. We are concerned about weed build up, but the trade off of expense compared to a transmission is the offset.
Mark
Jet, Jet Pump, Waterjet, Jet Drive vs Prop brian eiland Jet Drives 45 08-27-2010 09:04 PM
how bad an idea: PWC jet to surface drive srimes Propulsion 5 09-30-2008 02:53 AM
V drive with Perkins, what transmission? clctrader Boat Design 1 07-09-2007 02:50 AM
reverse flow on jet drive LEASEGUY Jet Drives 2 08-06-2006 09:19 PM
jet drive/bucket stripper Propulsion 1 01-20-2006 08:43 AM
