Go Back   Boat Design Forums > Design > Propulsion > Surface Drives
Old 09-02-2008, 06:13 AM
BarendGrobler BarendGrobler is offline
Rep: 6 Posts: 56
Surface drive side thrust
Hey all
I was wondering, how do/can you counter or compensate for the side thrust from surface props on single drive installations? Surely if just ignored, handeling will be hampered and the boat may even become unstable?
Old 09-03-2008, 02:17 PM
Rik's Avatar
Rik Rik is offline
Rep: 202 Posts: 111
It would be great if you gave more details on your boat, and the drive. A picture would go a long ways also.
Old 09-04-2008, 04:01 AM
Rep: 6 Posts: 56
I don't have such a boat, I'm asking out of a design point. I've been involved in the design of a couple of high speed patrol boats with twin surface drives; and in model testing we found the upward thrust from the surface props to have a significant effect on the trim of the boat, which then can be compensated for by moving the LCG further aft.
I was however now considering a surface drive for a smaller boat (7m) on which there is only room for one propulsion system, and I am concerned about the unsymmetrical nature of the drive; the upward prop force I mentioned above, now only being present on the one side of the prop (the side "slapping" into the water).
Surely this force will affect the roll-stability of the boat and have a large affect on the boat when banking into turns?
Old 10-20-2008, 08:18 AM
Rep: 472 Posts: 1,391
Side rudders
Originally Posted by BarendGrobler View Post
Hey all
Yes, your right. That is why many surface drives specially single engine small units like Arneson and Levi have side rudders to curtail that. On larger boats with two units it does not matter. Someone told me the run better with a central fin separating propellers. I have to try that one day.
CV drive-shaft/thrust bearing comments? M&M Ovenden Inboards 2 08-08-2007 04:03 PM
Stern shape design for surface drive/stern drive Alik Boat Design 8 06-15-2006 08:36 PM
Surface Drive Discussion Burns Boat Design 10 06-12-2006 03:47 AM
Surface Drive Info jprev Powerboats 11 11-21-2004 05:57 PM
surface and subsurface drive all in one tom kane Press Releases 5 11-08-2003 04:58 PM
