Go Back   Boat Design Forums > Design > Propulsion > Surface Drives
Old 12-30-2008, 02:57 AM
Jellyfish84 Jellyfish84 is offline
Rep: 10 Posts: 15
Surface Drive Quiries
hi i am new to this forum. and depending on the answers i am hopeing to gain i might be new new to surface drive setups.
just wondering if a surface drive setup would be anygood in a ski boat type of application, will it pull the boat out of a hole quick towing a skier. i ask this as i am thinking of adopting this type of settup on a boat i have for which i use as a pleasure boat to go the the reef fishing and also skiing. i know it would be great on the boat for the reef part but not sure on the skiing part. any help would be greatly appreciated.
cheers
jellyfish84
Old 12-30-2008, 03:32 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1528 Posts: 5,518
No no No, it wont pull out of the hole and it is extrememly dangerous for any one or anything in the viscinity of those surface props /meat grinders.
For similar reasons absalutely useless for fishing
Old 12-30-2008, 03:49 AM
Rep: 10 Posts: 15
oh ok thanks for the help. i when i said fishing i meant just crusing out to the reef flat out not slow trolling etc.
what are they like at starting off pretty slow i gather, until your on the plane.
cheers
Old 12-30-2008, 05:51 AM
masalai masalai is online now
masalai
Rep: 1630 Posts: 7,322
Application is longer distance high speed passages for larger vessels (40 ft & 12 plus tonnes) where fuel efficiency at high constant speed is a factor, - - or - - racing performance where fuel efficiency is not significant.... Frosty has on his boat and knows Sonny Levi, a designer & manufacturer...
Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story...
A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy...
Old 12-30-2008, 07:27 AM
Rep: 10 Posts: 15
i've seen levi drives ( LD 170) for small applications, 10 to 60 hp. so they must be suitable for smaler craft. i am running 100+ hp. i have also seen it on many smaller craft. yeh fair enough the skiing idea might be out of the question but for the high speed crusing it must be a great investment. i like the idea as it has a shallow draft (with trim especially) and it saves on fuel costs.
cheers
Old 12-30-2008, 11:08 AM
Frosty's Avatar
Sorry I was a bit short there. For what I know they do not pull well , mine certainly dont and will pull more the more they dry out and the props come clear, strange I know but they don't make Mastercraft for nothing.
100Hp is not enough for serious skiing anyway.
Surface is good for, vibration free economyand high speed .
For instance a good solid pull for tricking say 15MPH would be a pain with surface drives--nay impossible.
Electric Surface Drive justinDesign Surface Drives 2 09-23-2007 10:12 AM
Stern shape design for surface drive/stern drive Alik Boat Design 8 06-15-2006 08:36 PM
single surface drive? zingaroo Surface Drives 5 01-06-2005 09:03 AM
Surface Drive Info jprev Powerboats 11 11-21-2004 05:57 PM
surface and subsurface drive all in one tom kane Press Releases 5 11-08-2003 04:58 PM
