Go Back   Boat Design Forums > Design > Propulsion > Surface Drives
Old 07-14-2009, 10:16 PM
muddin redneck's Avatar
muddin redneck muddin redneck is offline
DO IT IN THE MUD!!!
Rep: 26 Posts: 94
Questions About Surface Drive Props
would it be possible to put a surface drive prop on a standard bass boat outboard? would i have to raise the motor out of the water some? if i did raise it out of the water would the water pump still work or need to be modified/changed? if these are not possible can i use a smaller engine to run the prop say up to 25hp horizontal shaft honda? could i mount it over the stern of the boat at a slight angle or do i have to cut a hole in the stern and run it strait out the back?
First Surface Drive ? MickeyFIN Surface Drives 10 12-22-2009 01:57 AM
Surface Prop Suppliers Quick 8 Surface Drives 6 03-25-2008 04:49 PM
surface prop repairs Frosty Surface Drives 0 04-01-2007 10:12 PM
Surface piecing prop mrs500g Surface Drives 11 11-24-2006 09:05 AM
Stern shape design for surface drive/stern drive Alik Boat Design 8 06-15-2006 08:36 PM
